Thread: 96 A4 Drivers Seat Removal
  1. 96 A4 Drivers Seat Removal
    Jul 2007
    HELLO EVERY ONE
    ANY BODY KNOW HOW TO GET DRIVERS SEAT OUT OF A 96 A4 1.9TDI TO FIT A BUSH ON SEAT SLIDE
  2. Re: 96 A4 Drivers Seat Removal
    Aug 2007
    New Romney Kent
    Providing its the same as most of the rest in the VAG range then:
    1. Slide the seat as far forward as possible,
    2. undo the two torx screws in the plastic trim on the seat rails (the torx is under a plastic cap)
    3. Slide seat back as far as possible
    4. Undo the two 13mm nuts on the front center of the seat
    5. Push seat back a couple of inches out of the mounting plate on the floor.
    6. Lift the front of the seat up approx 10" and unplug all of the plugs going to the seat.
    7. Push seat back, out of the rails and lift out.
    When you put the seat back in make sure the battery has been disconnected for at least 30 mins before you plug the airbag plug (yellow one) back in!!
  1. Golf MK4 GT 130TDI Heated drivers seat problem
    By GOLF_GTTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 31-10-2010, 09:55 PM
  2. A6 Seat removal
    By mark2004uk in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 29-07-2007, 10:50 AM
  3. Front Seat Removal
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2007, 03:01 AM
  4. Drivers seat knock
    By korgscrew in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-02-2007, 08:19 AM
  5. seat removal
    By cookie in forum Passat - Archive Topics
    Last Post: 21-12-2006, 11:34 PM
