Thread: A5 2.7 V6 Cylinder Numbering?
  1. Question A5 2.7 V6 Cylinder Numbering?
    Oct 2012
    Manchester
    Evening all,
    I've just been into the garage with my engine management light on to find out the glow plug on number 6 cylinder head needs to be changed. Clearly I want to do this myself but wanted to know if anyone can advise how they are numbered when lifting the bonnet.
    Kind Regards
    Jimmy
  2. Re: A5 2.7 V6 Cylinder Numbering?
    Nov 2012
    Edinburgh
    Jimmy,
    I've just joined up so that I can answer you.
    I've just been browsing to find same for my A6 3.0 Tdi Quattro Le Mans Avant - apparantly it is as follows and I found this in 2 different answers so it seems to be correct BUT perhaps you can verify it yourself.
    3 - 6
    2 - 5
    1 - 4
    front of car
    i.e. 3 is 'above' drivers feet and 6 above passengers stillettos!!
    Let me know how you get on and any tips as I need to sort my Cyl 2 plug.
    Adrian
    A6 2.4 se Avant
    1 1 0
  3. Re: A5 2.7 V6 Cylinder Numbering?
    Oct 2012
    Manchester
    Hi Adrian,
    Thanks for signing up, you were right and I've changed the glow plug.
    Only issue now is another error has been thrown up this time its the manifold sensor? Apparently a £500 part! Not sure what to do now as the engine mgt light is still on and want to get rid of it without the expense.
    Many thanks
    Jimmy
  4. Re: A5 2.7 V6 Cylinder Numbering?
    Nov 2012
    Edinburgh
    Jimmy,
    no worries - good luck with the new issue!
    Was changing the glow-plug easy? I need to do one myself. Any tips or advice would be great. If you know of a thread that walks you through it even better.
    slainte,
    Adrian
  5. Re: A5 2.7 V6 Cylinder Numbering?
    Oct 2012
    Manchester
    I'll be honest I got a friend to do it, I'm seeing him tomorrow so will ask for you, it only took a minute so don't think it was anything challenging.
    Good luck with it! I'll try and get you the answer.
  6. Re: A5 2.7 V6 Cylinder Numbering?
    Sep 2013
    A, A
    Quote Originally Posted by AdCol View Post
    Jimmy,
    3 - 6
    2 - 5
    1 - 4
    front of car
    Adrian
    A6 2.4 se Avant
    Brilliant information Adrian, my 3.0 V6 has started misfiring today, plugged in my OBD tool and got a a fault on cylinders 3 + 6. At least I now know which is which.
    Even better, I just found the garage receipt from September saying the garage replaced the two coil packs on these two pots.
    Thanks again for the info.
    Nev
  7. Re: A5 2.7 V6 Cylinder Numbering?
    Feb 2009
    West Yorkshire
    10 Post(s)
    Quote Originally Posted by j007jim007 View Post
    Try this Audi V6 TDi 2.7 & 3.0 Inlet Manifold, Swirl Flap Repair Kit.
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  1. Question S4 V8 Alloy cylinder block, worn cylinder bores?
    By Burfy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-05-2012, 01:27 PM
  2. Question cylinder down
    By hursty in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-07-2010, 07:43 AM
  3. cylinder down
    By manji in forum 100 - 200 - Turbo - 100 S4
    Last Post: 03-04-2009, 11:34 AM
  4. what cylinder is cylinder 2
    By deutsch in forum Golf MK5 - 2004 - 2009
    Last Post: 07-09-2008, 02:27 PM
  5. lock cylinder
    By barking71 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2007, 11:05 AM
