Thread: a3 8p rear passenger door won't open from outside
  1. a3 8p rear passenger door won't open from outside
    lancashire
    the rear passenger door won't open from outside but will open from inside and the annoying thing is its the door where the baby seat is
    its really driving me mad
    central locking seems to be working ok
    electric window is ok
    any tips on removing inside panel
    secondly any ideas what it could be
    thanks in advance jay
  2. Re: a3 8p rear passenger door won't open from outside
    46 Post(s)
    have you looked at the bottom of your thread for possible suggetions - Please Help Passenger door won't open from the outside?
  3. Re: a3 8p rear passenger door won't open from outside
    Jan 2012
    Coding Something
    Please in future advise us of the full car details, like year of car, as parts do & have changed over the years of the 8P release, that are relevant to your issue.
    The internal & external use a seperate mechansim to undo the door.
    I suspect the bar that connects the exterior handle to the actual door lock, has probably either come loose or the thread gripper(early 8P's) or yellow clip (all later 8P's) have broken of/come loose & allowed the bar to hang loose, is there a tapping noise when you swing/push/pull the door obviously when open if so then this is the bar/rod that connects the handle to the lock & door card has to come of to ascertain the fix needed.
  4. Re: a3 8p rear passenger door won't open from outside
    lancashire
    Tried working both handles together
    also looked on you tube but no vids of same vehicle
    its a 05 plate sport back with full electric window pack
    i am after removing door card to see if as mentioned cone ting bar but I don't want to damage it on removal so any tips on removing rear door card would be appreciated
    cheers jay
  1. Please Help Passenger door won't open from the outside?
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-02-2016, 12:54 AM
  2. Replies: 0
    Last Post: 07-02-2012, 12:25 PM
  3. passenger door want open
    By hairypothead87 in forum Vento - 1994 - 1998
    Last Post: 07-06-2011, 08:26 AM
  4. Replies: 5
    Last Post: 28-04-2008, 10:34 PM
  5. HELP Passenger door wont open
    By blacktdi in forum Golf MK4 - 1999 - 2004
    Last Post: 27-01-2008, 03:39 PM
