Thread: VW Golf 1991 mk2 GL Keeps coughing when shut off after a normal run.
  1. VW Golf 1991 mk2 GL Keeps coughing when shut off after a normal run.
    Sep 2012
    London
    Hello All,
    My VW Golf has developed this embarrassing continuous jerking cough when I turn it off for about close to a minute before it finally sort of rattles and shuts down. Could it be the spark plugs?
    I have attempted to find some thing in the Haynes manual but I don't know what I could be looking at.
    Please could someone tell me what I could check, replace or lubricate to alleviate this annoying issue. I always use very good oil (castrol magnetec) and regularly check the water etc.
    Your help and experience is appreciated.
    Ben
  2. Re: VW Golf 1991 mk2 GL Keeps coughing when shut off after a normal run.
    Aug 2011
    Meath
    Mk2? Could be carbon build up on the valves . is it carburetter, single point or injection? I doubt its the spark plugs
  3. Re: VW Golf 1991 mk2 GL Keeps coughing when shut off after a normal run.
    Sep 2012
    London
    Quote Originally Posted by paulkennedy View Post
    Its a Mark2 1.8 H reg Golf GL. Its definitely Carburetter.
  4. Re: VW Golf 1991 mk2 GL Keeps coughing when shut off after a normal run.
    Aug 2011
    Meath
    Something is causing it to "run on" Send me your engine code. Find the main ignition fuse get the engine up to normal temperature then with the engine running pull the fuse.
  5. Re: VW Golf 1991 mk2 GL Keeps coughing when shut off after a normal run.
    Great Dunmow (near Stansted Airport), Essex
    IT's most likely running too rich. Ours did it (very embarressing) and required a reconditioned carb, as there were many other things wrong with it too. Is it the standard Pierburg 2E2 (automatic choke) or Weber replacement? (manual choke)
    What are the revs doing before you try to switch off?
    1990 Black MKII Golf 1.8 GL. Otherwise known as 'Gumpert' Rampant "Rabbit"
    2011 Rosso Brunello Skoda Superb Estate Elegance 1.6 CR Greenline. Otherwise known as 'Sue'
    1988 Tornado Red MKII Golf 1.8 16valve GTI. Otherwise known as 'Hollie' - Project
  1. Please Help 1991 MK2 Golf Driver twin headlight problem
    By KeithOT in forum Golf MK2 - 1984 - 1992
    Last Post: 17-11-2011, 02:32 PM
  2. Radiator fan won't start, 1991 Mk2 1.3 Golf.
    By fssilva in forum Golf MK2 - 1984 - 1992
    Last Post: 25-05-2011, 06:13 PM
  3. mk2 1991 gti 8v wont start
    By TIMMk2 in forum Golf MK2 - 1984 - 1992
    Last Post: 15-05-2011, 01:35 PM
  4. 1991 80 Quattro 2.0 wont run
    By sparky1958 in forum Scotland
    Last Post: 16-08-2010, 10:03 PM
  5. Please Help golf 1.9 diesel coughing
    By karltheboy in forum Golf MK3 - 1993 - 1999
    Last Post: 07-10-2008, 01:38 PM
