Thread: All-weather lights instead of front fog lights
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
  1. All-weather lights instead of front fog lights
    Jun 2012
    Basingstoke, UK
    2012 A6 S-line Avant ex-demonstrator . I commented to the dealer that there did not appear to be any front fog lights in the lower side front grilles like there were on other cars in the showroom. After some consultation he returned and said they were integrated within the Bi-Xenon front light cluster. Sure enough something lit up when I tried the upper left button on the light switch cluster but it wasn't dark, or foggy, at the time! In the dark I now find they provide lighting to the side at the front of the car and reading the manual they appear to be called All-weather Lights. What are these lights for? Do they serve as fog lights or do they have a different purpose?
  2. Re: All-weather lights instead of front fog lights
    Jul 2011
    St Neots
    18 Post(s)
    As far as i can tell all weather light is the same as fog light. It cuts the top of the dipped beam off lower to minimise glare reflected back into your face in fog or snow and widens/intensifies the beam closer to you.
    A far as i can tell on mine, its the same effect as putting traditional fog lights on, but better because the dipped beam should glare less. Havent tried them in real bad weather but suspect they could be a real help.
    On a tangent:
    In the 12 years i have had cars with front fog lights i have only actually found them of use twice, once in fog and once in snow, both so bad i was forced into travelling under 20mph and turned the dipped beam off using just the fogs to cut glare. Why people use them on the motorway or A roads i will never understand. They light up 15 feet in front of you when you should be looking 300 feet in front. rant over.
    S6 Black Avant: Tech advanced, Matrix, Keyless entry, Sunroof, Speed limit display, Tow bar, Rear camera
    Golf GTI (for the Mrs) BMW M140i (for work and fun )
    0 4 1
  3. Re: All-weather lights instead of front fog lights
    Aug 2012
    Winchester
    Few reasons that people use them (apart from when they are really needed) - not that I agree with improper use as it only servers to blind other drivers
    1) Because they think it's cool to have a brace of lights showing in front of their car
    2) Because one or (both) of their headlights are not functioning and use fog lights (vs fixing the headlights)
    3) Because they think that even a slight bit of drizzle is 'bad weather' and switch on both front and back fog lights
    My previous car (Jaguar XF) didnt have fog lights - I dont think even the current model has fog lights and I am starting to see more and more cars not having fog lights - especially when they have Xenons that are expected to be ordered 90% of the time - I was told that with Xenon lights one didnt really need fog lights as the Xenons on dip were better than Halogen + fogs - but got to say I didnt get a chance to drive the XF in very bad fog, but it seemed to be fine in light fog
  4. Re: All-weather lights instead of front fog lights
    Feb 2012
    Epsom UK
    Again, at a slight tangent, the reason that ACC must be combined with Xenon or LED headlights is that the radar sensors are in the holes vacated by the fog lamps.
    A6 SE Estate 3.0 TDi with no style but loads of gizmos
  5. Re: All-weather lights instead of front fog lights
    Aug 2009
    We tried the all weather lights when we returned to the uk last sunday night in folkestone. it wasn't foggy but there was really torrential rain so visibility was pretty grim.
    I have adaptive xenons with these all weather lights, and i must admit they were great. the adaptive lights gave great perspective an lighting up the road, and then the all weather lights really illuminated the surface of the road in front of the car which is ideal when there is standing water on the motorway.
    much better than my previous a6!
  6. All-weather lights instead of front fog lights
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    I have enabled mine as kerb lighting when turning sharp corners at low speeds - I find it really helps on occasion. I haven't used them as fog lights yet though.
    MF.
    Sent from my iPad using Tapatalk HD
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  7. Re: All-weather lights instead of front fog lights
    Aug 2012
    Manchester
    Without meaning to thread jack Why do Xenon equipped cars have to have headlight washers? This is apparently law!
    The all weather lights are particularly good at night on country lanes when you have main beam on you get the short spread too. The lanes are use are pretty quiet so I don't have the issue of blinding people. I don't agree with using fogs unless the weather is bad usually but the beam spread I think is particularly useful on unlit roads
    His - 2012 A6 177bhp S-Line Daytona Grey standard apart from ambient light pack
    Hers - 2011 A1 122tfsi sport in black
  8. Re: All-weather lights instead of front fog lights
    Sep 2012
    Manchester
    Quote Originally Posted by foxy367 View Post
    Apparently the dirt refracts the Xenon beam / field in such a manner that it fragments / distorts causing glare / temporarily blindness to oncoming road users.
    Whether this is true or not is another matter but all Xenons do come with headlight washers (that pop off in the winter!) Red!
  9. Re: All-weather lights instead of front fog lights
    Feb 2012
    Epsom UK
    Quote Originally Posted by redadair777 View Post
    Could you explain what you mean by at last bit?
  10. Re: All-weather lights instead of front fog lights
    Sep 2012
    Manchester
    Hi Timothy, When you have Xenons on your car and when your lights are turned on either side lights, dipped or full beam your headlights are washed when you wash your windscreen with your jetwash.
    Consider this example:
    It is winter and the roads are full of grit / salt.
    It is pitch dark when you commute to work so you need your lights on
    After defrosting your car for a few minutes all windows are clear and you drive to work.
    within 1 minute of you driving to work your windscreen if filthy, you need to clean the windscreen with your jet wash.
    The trouble is your headlight washers are not fully defrosted, but the jet was nozzles are due to the engine heat or heated jet wash nozzles).
    However, in most cases you will not have any heated facility at your lights wash in the bumper. You keep washing your dirty window and it can't pop out because it is frozen shut. The part usually breaks with extreme wear and tear or the pressure build up makes the unit pop off because of the pressure against the plastic.
    I hope that (long winded story!) helps.... It's fairly common. A lot of BMWs used to suffer from it :-) Red.
    1 1 0
  1. No front fog lights
    By Harry2 in forum Golf MK6 - 2009 - 2013
    Last Post: 31-10-2010, 10:40 AM
  2. How To Front Fog Lights
    By phil miller in forum Golf MK5 - 2004 - 2009
    Last Post: 14-08-2010, 06:05 PM
  3. Front fog lights
    By mickymunn in forum Golf MK5 - 2004 - 2009
    Last Post: 14-11-2009, 07:38 PM
  4. Led Lights In Front Light Unit Or Fog Lights???
    By bigbadsexy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 18-09-2009, 07:28 PM
  5. Question Front Fog lights
    By Leespaige in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-05-2008, 01:28 AM
