Thread: Soldering onto rear windscreen
  1. Soldering onto rear windscreen
    Im doing a retro fit that requires me to solder two wires onto the the rear windscreen for an aerial thats in the screen but does not have the wires pre-wired/soldered on.
    My qustion is has anybody done this before with success ? I thought about using conductive glue/epoxy resin but not sure how well it work compared with a soldered joint.
    Any advice would be welcomed.
    Regards.
  2. Re: Soldering onto rear windscreen
    46 Post(s)
  3. Re: Soldering onto rear windscreen
    yep.
    Thank for directing me to the other posts. I wonder how there attached when the screen is manufactured tho, like is it warmed up to a certain temp before soldering to prevent heat shock to the glass ?
  4. Re: Soldering onto rear windscreen
    Aug 2011
    Meath
    I tried the conductive glue I found it quite thin it might work on a falt surface but it sucked rather than stuck on the car i tried it on (octavia)
  5. Re: Soldering onto rear windscreen
    Well I don't think i'm going to get a defiant answer but I think heating up the screen would reduce the thermal shock of the soldering iron but it is risky and could be costly but i'm surprised that a new rear windscreen is only £220 from Audi main dealer. I did not want to use the conductive glue but £7 v's £220 its a no brainer !!
  1. Please Help right indicator, rear fog light, rear windscreen heater, and brake lights!!!!
    By sutts85 in forum Early Passat Forum - Pre 97
    Last Post: 17-08-2011, 12:13 AM
  2. Froste looking rear windscreen??
    By AEightL in forum A8 - S8 - V8
    Last Post: 01-09-2010, 11:54 AM
  3. Question rear windscreen washer
    By shabzy in forum Polo - Derby - Lupo - Fox
    Last Post: 13-03-2009, 11:51 AM
  4. Please Help A3 Exploding Rear Windscreen
    By loubelou in forum Chat - Anything with wheels
    Last Post: 13-12-2008, 04:18 PM
  5. Remove the soldering
    By jake cott in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-02-2008, 04:07 PM
