Thread: Tyres Wearing On The Inside
Results 1 to 10 of 11
  1. Tyres Wearing On The Inside
    May 2012
    Ireland
    Hi.
    I've had my 2006 Allroad 2.7 TDi quattro tyres balance and the car tracked but it is still wearing the tyres on the insides on the front. The rears are less worn on the insides but still there is signs of wear on the inside of the tyre. They didn't track it at every level of the air suspension - just at "Automatic" level.
    The tyres are 255/25/17.
    Everything else seems ok with the car and there are no excessive loads.
    Anyone else experiencing this or is it just normal for an Allroad?
  2. Re: Tyres Wearing On The Inside
    If the front wear was due to tracking then I suspect the previuos owner noticed this and swopped the fronts to the rear and now the fronts have worn prior to the tracking. Once a tyres wear like this they do not even out with mileage but continue to wear unevenly. Do you have the print out of your tracking and what figures have been set. Regards Peter
  3. Re: Tyres Wearing On The Inside
    Nov 2010
    Watford
    I don't have any problem with mine, the tyre wear is even. Audi quattro system does need to have the wheels lined up properly. Was it laser 4 wheel tracked and how accurate did the get it set up?
    Interesting what Peter D says about the wear. You want to make sure your car isn't going to scrub a new set of tyres but you won't know if it's now OK until you fit new tyres. Dilemma!
    Make sure it is tracked properly and no wear on any suspension joints, then keep a careful look at the wear on your new set?
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  4. Tyres Wearing On The Inside
    46 Post(s)
    Get a 4 wheel laser alignment done at Audi as it is made for the quattro system and does everything to spec.
    £100 is what I paid for my alignment.
  5. Re: Tyres Wearing On The Inside
    Mar 2009
    Helsingborg, Sweden
    Quote Originally Posted by motionpotion View Post
    Hi.
    I have an Allroad and having had it laser tracked at the dealers have no issues with tyres. I noticed some wear when I was changing to summer tyres last year and as they were almost illegal decided to get the tracking done before buying a new set - Goodyear Asymmetric 2's. The dealer said (how true I don't know) that it takes some time to do the tracking as it must be checked at various levels.
    Not normal I would say......
    2012 VW CC 2.0 TDi
  6. Re: Tyres Wearing On The Inside
    May 2012
    Ireland
    I asked the dealer here in Ireland about the laser tracking and they said it's not laser but some radio frequency alignment. Have no clue how that would work.
  7. Re: Tyres Wearing On The Inside
    He had clearly been drinking. There is no such thing as radio frequency alignment. Regards Peter
  8. Re: Tyres Wearing On The Inside
    Aug 2011
    Meath
    what was he dealing? I want some of it!
  9. Re: Tyres Wearing On The Inside
    Apr 2012
    Aylesbury, Bucks
    He was perfectly correct - Google is your friend...
    Wheel aligner WA 970
  10. Re: Tyres Wearing On The Inside
    No, not quite. The radio frequency is 2.4Ghz and is solely for the wireless link from each device attached to each wheel to the computer system. This removes the cabling requirement. It does not use Radio Frequencies to measure the alignment. Regards Peter
  1. A6 rear tyres wearing on outside
    By krishcanag in forum Wheels and Tyres
    Last Post: 28-05-2012, 06:02 PM
  2. rear tyres wearing badly on the one side...
    By lemmy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-10-2008, 07:54 PM
  3. What make tyres for hard wearing
    By energize in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 06:12 PM
  4. Wearing tyres
    By James--Ryan in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2007, 11:38 AM
  5. Longer Wearing Tyres?
    By Glaikit in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-07-2007, 12:05 PM
