Thread: turbo seals gone, getting a new turbo, will i need a remap ??
Results 1 to 10 of 13
  1. turbo seals gone, getting a new turbo, will i need a remap ??
    Apr 2012
    Newcastle
    right where to start, was on the phone to the girlfriend the other day and she told me the oil light kept flashing on, so talked her throught topping up the oil , she then told me a few days later that it didnt feel like the car was pulling right while on boost, so had a mate look at the car tonight and it seems there is oil leaking from the intercooler and he thinks the seal has gone on the compressor............... so i think i will be needing a new turbo , ive found this
    K04-015 Turbo Audi A4 A6 VW 1.8L 1.8 Upgrade K03 Turbocharger 53049880015 210HP | eBay
    only question is can i replace the turbo with this and will it need a remap , what will happen if i dont get it remapped etc?
  2. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Pembrokeshire
    22 Post(s)
    a small bit of oil around the boost pipes is quite normal but i would check the turbo for play in the bearings. what is more worrying is the oil light coming on. it might be an idea to drop the sump and give it all a good clean. if you do a search you will find your engine is prone to oil problems.
  3. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Apr 2012
    Newcastle
    doh well i am nowhere near my car at the moment so i think things are going to have to wait, think the problem is defo with the turbo reason i think this is due to the car not pulling well so the plan was to get the uprated turbo, get a mate to install it, recon the old turbo and sell that just want to see if the i can run the turbo without re-mapping it, then when i get home to it if there is no more leaks get an intercooler and new exhaust system then get it re-mapped
  4. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Pembrokeshire
    22 Post(s)
    fair play. when the new turbo goes the same way, and not until then, please refer back to my previous post about sludge problems with the 1.8t.
  5. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Aug 2011
    Meath
    Did you check the quite likely to fail N75 valve first?
  6. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Apr 2012
    Newcastle
    the only reason i cant touch the car is because i am in Afghanistan
    i will get the sump cleaned and new a oil filter plus more fresh oil before i buy a turbo then
    also i have no idea what the N75 valve is
  7. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Aug 2011
    Meath
    N75 controls the turbo boost, it will show on a scan, sludge is quite likely anyway but easy if messy to clean
  8. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Pembrokeshire
    22 Post(s)
    Quote Originally Posted by steveo701 View Post
    respect
    1 1 0
  9. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Oct 2005
    Assuming you're out there with the Forces and not on holiday - thanks for doing what you do.
    2 0 0
  10. Re: turbo seals gone, getting a new turbo, will i need a remap ??
    Apr 2012
    Newcastle
    right so i want a full good and proper oil change , new filter , and the sump removed and cleaned out
    any one got a pic of the N75 valve ? need to show my mate and tell him what to do, is there anything else i could check out ?
    cheers for the support guys. yes Sam , British Army i am running the training package to the troops before they deploy out on the ground, lets just hope they all come back
    2 0 0
  1. Leaking oil thru turbo seals
    By Wilts in forum 1.8T - Engine
    Last Post: 23-09-2012, 09:04 PM
  2. Please Help Mk V Golf Turbo Seals
    By samz77 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-05-2011, 09:11 AM
  3. Turbo oil seals gone
    By mikea31.820vt in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-11-2010, 08:41 AM
  4. Please Help Turbo Boost Pipe Seals Leaking
    By Sloggs in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-06-2010, 04:10 PM
  5. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
