Thread: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
Results 1 to 8 of 8
  1. Question "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Sep 2012
    Dundalk ireland
    Evrytime i change gear in my audi i have to gently accellerate to prevent this banging that is happening!! In other cases i release the accelerator and this bang noise happens again.. Its not a repetative bangin noise.. It just happens the once when changing gear or when releasing the accelerator.. Dont want to be doing any unneccessary work to the car until i know the problem.. Any help atal would be great thanks
  2. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Mar 2008
    High Wycombe
    You'll probably get more help posting this in the A4 B6 forum. i expect Esh may be along shortly to move this thread for you.
    Have you looked underneath the car yet? If it's thumping on acceleration / deceleration, I'd suspect that one or more of the suspension joints or mountings is loose / worn.
    I think the first piece of necessary work is either to jack it up and check all the suspension mounts and joints, or get a mechanic to check this for you.
    You could also check the gearbox mounts - is the gear stick moving at the same time as the banging?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Sep 2012
    Dundalk ireland
    I didnt know how to post it on the a4 b6 forum.. Yea i checked underneath it and seen dat there was a rubber mount gone to the underside at d back of the gear box... The gear stick doesnt move when the banging happens but it vibrates alot when driving... Must get the suspension checked out.. Thanks for your help
  4. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Oct 2005
    I moved dis to da rite forum for u, y0!
    0 3 0
  5. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Sep 2012
    Dundalk ireland
    Cheers sam
  6. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Aug 2011
    Hornchurch
    lol
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  7. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    london/ UK
    Take it to a garage and put it on a ramp and replace what's broken ! Simples !
  8. Re: "b6 audi a4" banging/thumping feel and noise when releasing throttle and changing gear rapildy
    Aug 2010
    Durham, UK
    Did you every get to the bottom of this?
    I had a similar clunking noise when I dipped the clutch whilst changing up and I thought there was a gearbox or clutch problem. I eventually worked out that it was due to the nose dipping down when the accelerator was released for a gear change as I could make it do the same without dipping the clutch and simply releasing the accelerator. It only happened in the lower gears, when the nose-dipping forward would be more pronounced.
    A local trustworthy garage had the car for an entire morning and they checked all sorts but couldn't find the problem. They assured me that nothing dangerous was present but that I would need to simply carry on, allow the noise to develop and bring it back.
    It did seem to be getting worse and localising more and more on the left front wheel. So one day I simply took the wheel off to have a look myself. Nothing abnormal that I could see.
    But after putting the wheel back on, the noise has completely disappeared. With hindsight, the noise only started after my wheels were taken off to have my dirty, noisy front brakes stripped and cleaned.
    So perhaps the wheels weren't re-torqued in the correct manner? Whatever - the noise has gone now..
    May be nothing at all to do with your problem but both I and the garage didn't even think of the wheel as being the problem, so I thought I'd add my tuppence worth...
  1. Off throttle "BANG" in 2nd gear (A4 1.9TDI)
    By Gwilo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2012, 06:12 PM
  2. Replies: 11
    Last Post: 13-08-2011, 08:28 PM
  3. Cleaned EGR valve now car is "jumpy" in throttle response
    By conor2949 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 09:42 PM
  4. Audi A4 Avant - Panel Display - "In 1 "or "In 2"
    By infrance in forum Audi A4 - Archive Topics
    Last Post: 05-03-2007, 03:20 PM
