Thread: B6 Passat - Reverse Light Problem
  1. B6 Passat - Reverse Light Problem
    Jul 2011
    Ireland
    The right rear parking light isn't working on my 2005 B6 passat. Left one is working just fine which is odd.
    Things I've tried so far:
    - Changing the Bulb
    - Swaping over the bulb housing. Tried the one on the opposite side which works and it didn't work when I switch it over.
    - Checking the fuses (only one fuse for both reverse lights on a b6 passat).
    So I've eliminated the bulb housing and bulb as modes to failure. Any other ideas what it could be or how i would go about diagnosing it?
  2. Re: B6 Passat - Reverse Light Problem
    46 Post(s)
    the b6 only has one reversing light
  3. Re: B6 Passat - Reverse Light Problem
    Jul 2011
    Ireland
    Really..... why is there two bulbs either side then?
  4. Re: B6 Passat - Reverse Light Problem
    Sep 2011
    glasgow scotland
    isnt one side reverse and the other a fog light same as my jetta looks like same clusters
  5. B6 Passat - Reverse Light Problem
    46 Post(s)
    Quote Originally Posted by chody View Post
    That's correct - one side is the reversing and the other the rear fog.
  1. Golf mk 5 reverse light and fog light swap for lhd rules
    By mojorising in forum VCDS - Help Requests
    Last Post: 21-04-2012, 09:33 AM
  2. 2003 A4 2.5tdi Quattro Avant - Reverse light problem
    By theminiman2002 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-01-2011, 10:40 AM
  3. Rear fog light / reverse light fault (golf 5)
    By 85turbo in forum VCDS - General Questions
    Last Post: 03-09-2010, 11:30 PM
  4. Please Help Reverse and Brake light problem
    By Dorneyed in forum Touran - Sharan - Caravelle
    Last Post: 08-01-2009, 03:08 PM
  5. A4 Estate (1997) reverse light problem
    By bigcrags in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-04-2007, 10:52 AM
