Thread: Alternator removal to replace starter motor
  1. Alternator removal to replace starter motor
    Jul 2011
    london uk
    HI Could someone please advise me what size Allen key i need to release the poly belt tensioner so i can remove my alternater on a audi allroad 2.5tdi 2001 as been advised i need to remove the alternator to replace starter motor hope this is correct
    Thanks all
  2. Re: Alternator removal to replace starter motor
    If you already have the bumber off and the front in the service postion and covers off then you can see the allen key hole. 10mm from memory. You need to tell us the engine code like AKE, it is on the ID Label in the spare wheel bay. Have you got two thin 32 mm spanners to remove the Viscous fan and do you have a manual. Regards Peter
  3. Re: Alternator removal to replace starter motor
    Jul 2011
    london uk
    Hi Peter
    THANKS
    The engine code is AKE Have not been able to remove bumper but have felt allen key hole and tried a 12mm in it but is to small Unless i am feeling the wrong allen key hole but it is right next to the tensioner as shown on elsawin diagram
    Tony
  4. Re: Alternator removal to replace starter motor
    Jul 2011
    london uk
    Viscose fan and shrouding around pulleys all removed Painfull removing fan chopped my bloody finger and is it bloody lol
    Tony
  5. Re: Alternator removal to replace starter motor
    Without the front in the sevice position it is very very tight. Good Luck. Regards Peter
  6. Re: Alternator removal to replace starter motor
    Dec 2010
    Swindon Wiltshire
    It looks bloody tight, but can it be done?
    The motor looks like it protrudes quite far into the housing meaning it needs to be withdrawn quite far, the alternator must be in the way?
    I also have a small diameter pipe coming from the block that looks like a water drain of sorts right in the way.
    Any help with confirming this would be most appreciated as it means I get someone else to do the job. thanks.
  7. Re: Alternator removal to replace starter motor
    Ayrshire, Scotland
    18 Post(s)
    If it is the tensioner for the large alternator belt, on my allroad AKE it was a 17mm hex
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. Please Help A4 1.9TDI SE Avant 1998 - Starter Motor Removal
    By wild01 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-04-2011, 02:49 PM
  2. Tricky starter motor removal.
    By driver2008 in forum Golf MK3 - 1993 - 1999
    Last Post: 06-03-2011, 11:39 PM
  3. Starter motor removal
    By waynetdi130 in forum Beetle 2000-
    Last Post: 24-11-2010, 08:20 PM
  4. 2.7 V6 BiTurbo A6 AJK Starter Motor removal.. which way out?
    By owbow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-04-2010, 01:40 PM
  5. 1.4 Polo Starter motor removal
    By dickelms in forum Polo - Derby - Lupo - Fox
    Last Post: 23-07-2009, 12:22 AM
