Thread: Passenger Airbag always on. Is this normal.
Results 1 to 10 of 11
  1. Passenger Airbag always on. Is this normal.
    Sep 2012
    Romford, UK
    In my Audi A6 2006, every time I turn on the ignition, it shows me that passenger airbag is on. I thought it should only turn on if there is a passenger in the seat. Is this how it is supposed to be?
  2. Re: Passenger Airbag always on. Is this normal.
    Apr 2012
    Aylesbury, Bucks
    Mine does exactly the same - the warning light illuminates for a couple of seconds, then goes out.
  3. Re: Passenger Airbag always on. Is this normal.
    Sep 2012
    Romford, UK
    I see. Not sure how to check if it is on or off when I start driving...
  4. Re: Passenger Airbag always on. Is this normal.
    Jul 2011
    Near Uxbridge
    Its normal...you can turn the airbag off in the glovebox IIRC.....but not sure why you'd want to unless you have a baby seat in the front. Better to leave it on than forget to turn it on and crash!!
  5. Re: Passenger Airbag always on. Is this normal.
    Apr 2012
    Aylesbury, Bucks
    There is a key-hole inside the glove box that allows you to turn the passenger airbag off in the case of transporting a child (under 3, but they'd be too big over three anyway!) in a rear facing carrier in the front passenger seat. this is the ONLY time you should turn it off.
  6. Re: Passenger Airbag always on. Is this normal.
    Sep 2012
    Romford, UK
    Thanks for the info... I used to live in the US before. I owned a Toyota there and it was standard that the Passenger air bags turn on if there is a passenger in the seat. Otherwise they are off. I was assuming Audi would be similar, but surprised that they can only be always on or always off. (In US it is illegal to have car seats in the front seat... so probably there is no option to completely turn off the air bag.)
  7. Re: Passenger Airbag always on. Is this normal.
    Aug 2012
    East Sussex, UK
    Quote Originally Posted by rafletcher View Post
    Same here.
    2006 (C6) A6 Avant SE. 3.0 TDI V6. Quattro. 6 Speed Manual. Adaptive Air Suspension.
  8. Re: Passenger Airbag always on. Is this normal.
    Aug 2012
    East Sussex, UK
    Quote Originally Posted by sapstar View Post
    What if you only have a 2 seater car?!
  9. Re: Passenger Airbag always on. Is this normal.
    Sep 2011
    Lurking over a keyboard ...
    If airbag is off on centre console above AC controls I think a light illuminate which reads "Passenger airbag off"
  10. Passenger Airbag always on. Is this normal.
    46 Post(s)
    The light will illuminate permanently when you have manually switched the passenger airbag off.
    It's normal for the light to illuminate when starting up.
    1 1 0
  1. Airbag Fault after trying to switch back on Passenger Airbag
    By platty25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-08-2011, 10:47 AM
  2. Question how do i switch passenger airbag off
    By martink in forum Audi A3 - Archive Topics
    Last Post: 28-12-2008, 10:09 PM
  3. passenger airbag deactivation
    By simurday in forum In Car Entertainment
    Last Post: 19-10-2008, 06:53 PM
  4. Passenger airbag
    By weepiglet in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-02-2008, 11:37 AM
  5. Passenger Airbag
    By Samcat in forum Passat - Archive Topics
    Last Post: 15-11-2006, 10:03 AM
