Thread: A4 Rear discs
Hybrid View
  1. A4 Rear discs
    Feb 2007
    I need to renew my rear discs on my R reg a4 avante 1.9tdi auto with ABS i have noticed the disc includes a integral bearing will i have to replace with the same unit or can i replace with a normal disc and a seperate bearing the front seem to be seperate?
    dean
  2. Re: A4 Rear discs
    Aug 2007
    hi deano2, i just replaced my rear discs and used new wheel bearings too cos they're dirt cheap from euro car parts. just stick the bearing seats in the freezer for an hour or so then you can use a brass drift or similar to tap them into place. grease and fit the rear race, followed by the grease seal,then the front one when the disc is in place. you will also need to tap the abs ring off the old discs with a punch through the wheel bolt holes and fit to the new ones
    enjoy!!
  3. Wink Re: A4 Rear discs
    May 2007
    Just changed rear discs on my Audi 1999 Tdi and was advised to change ABS rings at same time, glad I did, old ones looked thin and brittle and there not too expensive either, Audi charging £12.49+vat each but managed to buy at Europarts for £9.00
  4. Re: A4 Rear discs
    Feb 2007
    Thanks guys for your wisdom will try this weekend.
  1. rear pads & discs
    By davidlandy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2007, 09:32 PM
  2. front discs
    By mikeya4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-08-2007, 10:33 AM
  3. MK3 GTi Changing Discs - please help
    By twallis in forum Golf MK3 - 1993 - 1999
    Last Post: 31-07-2007, 08:23 PM
  4. Brake Discs
    By mwvw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-07-2007, 01:33 PM
  5. Discs - discolour
    By Mav2006 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 11:40 AM
