Thread: Meaning of compressor shut off code
Results 1 to 10 of 18
  1. Meaning of compressor shut off code
    Jun 2012
    Ireland
    This is a long saga,for me and eventually im gonna have to bring my '07 A6 to the shop but my A/C shows a shut off condition of 12. Ive found a definition of the code -----> 12 = Compressor off (shut-off request from Engine Control Module (ECM) via CAN) but what does that actually mean,can I find out more info in diagnostics about it?
    Any thoughts appreciated
  2. Re: Meaning of compressor shut off code
    46 Post(s)
    what was it scanned with?
  3. Re: Meaning of compressor shut off code
    Jun 2012
    Ireland
    Vcds
  4. Re: Meaning of compressor shut off code
    46 Post(s)
    do you have the full fault code?
  5. Re: Meaning of compressor shut off code
    Sep 2011
    Lurking over a keyboard ...
    J If a compressor shut-off conditions applies (display group 002) the AC compressor regulating valve -N280 cannot be activated, including during final control diagnosis.
    J If no pressure signal is detected by the refrigerant pressure/temperature sender -G395-, the AC compressor regulating valve -N280 must not be activated.
    J By way of the signal the Climatronic control unit -J255 calculates the pressure in the refrigerant circuit.
    J If the refrigerant circuit is correctly charged, a pressure of 2.6 bar is set at a temperature of -3°C. So that no fault is stored at low temperatures, the Climatronic control unit -J255 only detects a fault in the refrigerant circuit at a pressure below 1.8 bar (set at -12° C). At this temperature the measured value of the refrigerant pressure/temperature sender -G395 is no longer evaluated, however.
    J On the Audi A6 a refrigerant pressure/temperature sender -G395 is fitted. It exchanges information with the Climatronic control unit -J255 over the data bus system of the air conditioner LIN bus. Consequently, no high-pressure sender -G65 may be fitted in the Audi A6 (it sends a square signal). So make sure you have the correct part number (the two components cannot always be distinguished by their housings).
    Measured value block 002
    Display zone 1
    Current valid compressor shut-off condition
    J Readout = "XX"
    Display zone 2
    Last compressor shut-off condition
    J Readout = "XX"
    Display zone 3
    Last-but-one compressor shut-off condition
    J Readout = "XX"
    Display zone 4
    Last-but-two compressor shut-off condition
    J Readout = "XX"
    Breakdown of compressor shut-off conditions
    0 Compressor on (no shut-off condition detected.)
    1 Compressor off (pressure in refrigerant circuit was or is too high.)
    2 Compressoroff (basic setting not performed or not performed without error.)
    3 Compressor off (pressure in refrigerant circuit is too low.)
    4 Compressor off (engine nor running or has been running for less than 2 sec.)
    5 Compressor off (engine speed is below 300/ min.)
    6 Compressor off (compressor switched off by ECON118°C.)
    12
    Compressor off (request from the engine control unit, via data bus.)
    13
    Compressor off (faulty signal from refrigerant pressure and temperature sender
    -G395.)
    14 Compressor off (fault in data bus system.)
    15 Compressor off (the pressure in the refrigerant circuit in this driving period was at least 30 times too
    high.)
    16 Compressor off (the measured temperature downstream of the evaporator has for over a minute been below
    0°C.)
    17 Compressor off (measured temperature downstream of evaporator below -5°C.)
    18 Compressor off (there is no valid measured value for theambient temperature, possibly both
    ambient temperature sensors -G17 and fresh air blower intake duct -G89 defective.)
    19 Compressor off (-Climatronic control unit -J255
    was switched on via the "auxiliary heater" function.)
    20 Compressor off (readout currently vacant)
    21 Compressor off (measured ambient temperature wasbelow -8°C and is still below
    -5°C, there is no request for automatic recirculated air mode or the measuredambient temperature
    was below +2°C and is still below +5°Cand the "automatic recirculated air mode" function is not
    active.)
    22 Compressor off (measured passenger compartment temperature below +8°C. The measured
    ambient temperaturewas below -8°C and isstill below -5°C. Arequest for
    recirculated air mode has been received.)
    23 Compressor off (via the data bus system a fault message for activation of the
    radiator fans was sent, e.g. by therelevant engine control unit,and received bythe
    Climatronic control unit -J255.)
    24 Compressor off (readout currently not used.)
    25 Compressor off (readout currently not used.)
    Ref:- Audi Portal: Actuators Diagnostic . Audi A6 4F (2005- ). N280
    *** view image in above link ***
    A and B - Connector of AC compressor regulating valve -N280 -N280
    The electric AC compressor regulating valve -N280 is pushed into the compressor and is secured by a spring ring.
    It forms the interface between the low, high and crankcase pressure in the compressor and is the precondition for clutchless operation.
    The adjustment of the swash plate is effected by these different pressures.
    That means, if a higher cooling power is required, for example, the regulating valve is activated by the Climatronic control unit -J255.
    A pulse width modulated voltage signal moves the plunger in the regulating valve. The duration of the applied voltage determines the adjustment travel.
    The adjustment alters the opening cross-section between the high pressure and the pressure in the crankcase of the compressor. The crankcase pressure increases and, by way of the piston stroke, effects a greater skew of the swash plate.
    K Notes:
    J If an inadequate vehicle voltage is applied, faults may occur in the air conditioning system, or it may fail altogether.
    J If the regulating valve fails, the wash plate positions itself perpendicular to the longitudinal axis of the compressor such that the cooling function is disabled.
    A Air conditioner; Rep.Gr. 87; Checking switch-on signal for AC compressor regulating valve -N280
    A Current flow diagram; ELSA
    Checking AC compressor regulating valve -N280
    The illustration shows a signal with a ratio of approx. 80%.
    The pulse width -A- is dependent on desired refrigerant output, the vehicle electrical system voltage etc. (the current is regulated by the Climatronic control unit -J255- via the AC compressor regulating valve -N280- across the range -A-).
    The signal interval -B- is always 2 milliseconds (corresponding to a frequency of 500 Hertz).
    The signal ratio is produced from the ratio between the pulse width -A- and signal interval -B-.
    Your post:-
    Quote Originally Posted by TheFixer View Post
    So I'm finally getting back onto this,here is some HVAC stats.Still no fault codes
    5.6 bar Refrigerant Circuit Pressure 21.0°C Evaporator (G263) Temperature
    20.0°C Air Intake (G89) Temperature
    17.0°C Ambient (G17) Temperature
    24.0°C Dash Panel (G56) Temperature
    2880 /min Temp. Sensor Blower Speed
    71.0°C Coolant Temperature
    0.0 Compressor Torque Status
    3.0 Nm Compressor Torque
    16.0°C Refrigerant Temperature
    Im going to get the air/con serviced just to rule that out......
  6. Re: Meaning of compressor shut off code
    Jun 2012
    Ireland
    The HVAC itself gives no fault code but here some data I gathered today.
    0.650 A A/C Regulating Valve (N280)
    63.5 % A/C Regulating Valve (N280)
    0.0 Current Shut-Off Condition
    12.0 Last Shut-Off Condition
    23.0°C Left Vent (G150) Temperature
    23.0°C Right Vent (G151) Temperature
    Not Occup. Center Vent (G191) Temperature
    22.0°C Evaporator (G263) Temperature
    19.0°C Air Intake (G89) Temperature
    15.0°C Ambient (G17) Temperature
    22.0°C Dash Panel (G56) Temperature
    2820 /min Temp. Sensor Blower Speed
    0 (zero) is compressor on i think, but my system will not blow cold air. Had gas checked but was ok.
    Just thinking is 12 just meaning that when I turn off the ignition the ECM is sending the off request to turn off the compressor? Thus showing a 12 for compressor condition?
  7. Re: Meaning of compressor shut off code
    Sep 2011
    Display zone 1
    J Readout = "XX"
    Display zone 2
    J Readout = "XX"
    Display zone 3
    J Readout = "XX"
    Display zone 4
    J Readout = "XX"
    Which display zone data from??
  8. Re: Meaning of compressor shut off code
    Jun 2012
    Ireland
    Is this what you mean?
  9. Re: Meaning of compressor shut off code
    Sep 2011
    YEP.... thank you for screen shot... I will check mine and post screenie...
    I was digging around to see part no for N280 valve and found none...
    Then searched web and seems as if valve is only available with compressor...
    Something for you to read Link:- a/c not cooling
    My car before car started... note code 6 as ECO button had been on... you are correct about code 12...
    My car started... with temp set on AC as 19... outside temp on DIS 17...
    My car started... with temp on lowest AC setting "LO"....
    If you look at MVB's 001 (Group 001) when car not started/AC off, you can see N280 is 0.0A, 0%
    Then as car started and AC on temp"19"... A=AMPS go up... AC reg valve work...
    Then as AC temp lowered... AC working more... AMPS used go up... AC reg valve % climb...
    Please check MVB/group 001... post results...
    Another one which maybe good to check...
    Measured value block 011
    Front cold air flap control motor -V197
    Display zone 1
    Actual feedback value ofcold air flap control motor potentiometer -G315 (specification "10 ... 250").
    Display zone 2
    Specified feedback value of(specification "6 ... 254").
    Display zone 3
    Learned feedback value ofcold air flap control motor potentiometer -G315 at lower limit (cold air flap closedspecification "10 ... 70").
    Display zone 4
    Learned feedback value of cold air flap control motor potentiometer -G315 at upper limit (cold air flap open, specification "200 ... 250").
    Ref Link 1:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Climatronic J255
    Ref Link 2:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Climatronic J255
    Ref Link 3:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Climatronic J255
    Ref Link 4:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Climatronic J255
  10. Re: Meaning of compressor shut off code
    Jun 2012
    Ireland
    Thanks!!!
    I checked your screen shot figures against my car with the same temp settings. Only value with no change is the refrigerant pressure.It reads 4.4Bar no matter what setting. The amps and valve percentage values change in line with what you have shown me.
    I should get to check those other things later but kids have me busy at the moment lol
    Could the Refrigerant pressure/temperature sender -G395 be the issue?
  1. Allroad air compressor vs. A6 rear self leveing compressor
    By g.suggy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-06-2012, 11:00 AM
  2. Soot and thermal load of oil ch.47 & ch.48 (add.17) - Meaning?
    By Novica in forum VCDS - General Questions
    Last Post: 02-04-2009, 07:49 PM
  3. MKIV Golf Fault Code: P1609 "Crash shut-down activated"
    By laugharne in forum Golf MK4 - 1999 - 2004
    Last Post: 18-09-2007, 08:05 PM
  4. Error code meaning?
    By mack10 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-06-2007, 04:04 PM
  5. Beeps !!!!!!!! meaning just what ?
    By Whocantellyer in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-02-2007, 05:19 PM
