Thread: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
  1. 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Sep 2012
    West Yorkshire
    Hi All,
    Got a 1.8 1999 Passat that is running roug. I did a check on VCDS lite and got the following error - 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Yesterday I replaced the sensor with a new one (blue - square 4 pin) and cleared the code. Took it for a 20 min drive and the code didn't come back. However today I have been on a 2 hour trip and the code has re-appeared. Any ideas what it could be?
  2. Re: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    135 Post(s)
    2038 Post(s)
    Monitor the signal from the sensor in measuring blocks on a long drive and see if the temperature goes from hot when standing still and then cools considerably whilst driving. If it does, you have a faulty/missing thermostat.
  3. Re: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Sep 2012
    West Yorkshire
    Dumb question...is the faulty / missing thermostat different to the engine coolant sensor?!
  4. Re: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Sep 2012
    West Yorkshire
    Quote Originally Posted by SkipFeeney View Post
    Just taken it for a 20 min drive and it does display the symptoms you mentioned. When driving the temp gauge seems to stay under 70, i then parked up and left it idling and it went to 90. Then when i set off it went back to 70 - is this not normal then? I also noticed on a long motorway drive the temp stays around 70 - i just assumed enough air was going to the engine to cool it?
  5. Re: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    135 Post(s)
    2038 Post(s)
    Fit a new thermostat, if you don't know the difference between a coolant temperature sender and a thermostat I begin to worry, even my wife worked that one out!
    This is a thermostat
    On an ADR engine the thermostat is under the black plastic cover at the end of the hose with two 10-mm headed M5 hex head set screws.
  6. Re: 16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Sep 2012
    West Yorkshire
    Lol thanks Crasher - I have to start somewhere
    Tonight i removed the thermostat and attempted to fit a new one, however I can't get it or the O ring to stay in place long enough to get the hose back on and the bolts fastened!
    Is there a trick to it?
  1. Crazy ongoing coolant temp sensore issue (G62)
    By skragg in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-03-2012, 01:15 PM
  2. Replies: 5
    Last Post: 28-03-2012, 10:27 AM
  3. Where is my G62 coolant temp sensor?
    By abimogen in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2011, 06:35 PM
  4. Question mk4 golf 1.6 g62 implausible signal
    By sean gibson in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2009, 10:55 AM
  5. Eng Coolant Temp Sensor G62 Replacement
    By Nildefects in forum Audi A3 - Archive Topics
    Last Post: 15-10-2008, 01:19 PM
