Thread: I have bought a new (02) Passat
  1. I have bought a new (02) Passat
    May 2010
    Tregarth UK
    Hello,
    I must be a glutton for punishment! I bought a 02 Passat SE TDI 130pd estate on 85k, on driving it initially I thought wow this is quick, until.... UNTIL!
    I tried overtaking on the motorway, I dropped to 4th put my foot down and...AND nothing! No turbo! Until I stopped at services, carried on with a turbo, and then it disappeared again!
    Below are the results of a VCDS (godbless it) scan - the car is under a 3 month VW warranty so I want to get everything fixed ASAP by VW. On a brief search - I'm guessing MAP/Thrust sensor, stuck turbo vanes or n75?
    Chassis Type: 3B - VW Passat B5Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58 ,75,76,77
    Address 01: Engine Labels: 038-906-019-AVF.LBL
    Controller: 038 906 019 GS
    Component: 1,9l R4 EDC 0000SG 1525
    Coding: 00005
    Shop #: WSC 05314
    WVWZZZ3BZ2E382758 VWZ7Z0A4757533
    2 Faults Found:
    17965 - Charge Pressure Control: Positive Deviation
    P1557 - 35-10 - - - Intermittent
    18263 - Powertrain Data Bus: Software Version Monitoring
    P1855 - 35-00 - -
    Readiness: N/A
    Address 03: ABS Brakes Labels: 4B0-614-517.LBL
    Controller: 4B0 614 517 G
    Component: ABS/ESP front 1728
    Coding: 04255
    Shop #: WSC 05311
    No fault code found.
    Address 08: Auto HVAC Labels: 3Bx-907-044.LBL
    Controller: 3B2 907 044 J
    Component: CLIMATRONIC B5GP 0004
    Coding: 17000
    Shop #: WSC 05311
    Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
    Controller: 1C0 909 605 B
    Component: 0A AIRBAG VW51 04 0004
    Coding: 12353
    Shop #: WSC 05311
    Address 17: Instruments Labels: 3B0-920-xx5-17.LBL
    Controller: 3B0 920 927 A
    Component: KOMBI+WEGFAHRSP VDO V07
    Coding: 05415
    Shop #: WSC 00000
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    30-10 - Open or Short to Plus - Intermittent
    Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 05314
    Address 46: Central Conv. Labels: 1C0-959-799.LBL
    Controller: 1C0 959 799 B
    Component: 6U Komfortgerát HLO 0003
    Coding: 00258
    Shop #: WSC 05311
    3 Faults Found:
    01134 - Alarm Horn (H12)
    49-10 - No Communications - Intermittent
    01135 - Interior Monitoring Sensors
    36-10 - Open Circuit - Intermittent
    00931 - Locking Module for Central Locking; Rear Right (F223)
    27-10 - Implausible Signal - Intermittent
    Address 56: Radio Labels: 1J0-035-18x-56.LBL
    Controller: 1J0 035 186 D
    Component: RADIO SON 0004
    Coding: 05403
    Shop #: WSC 05311
    2 Faults Found:
    00852 - Loudspeaker(s); Front
    00853 - Loudspeaker(s); Rear
    End --------------------------------------------------------------------------------------------------
    Any suggestions over what I should do (i.e. what should I tell VW?) or other advice would be as always greatly appreciated!
    Kieran
    VW Passat Estate SE 1.9pd Tdi (130 AWX) 2002 162k
  2. Re: I have bought a new (02) Passat
    Pembrokeshire
    22 Post(s)
    more than likely carboned up vanes.
  3. Re: I have bought a new (02) Passat
    Jul 2010
    Brighton
    Personally don't think you should do anything except take it back and calmly tell them the problems and say that you would like a free loan car until your is completely fixed FOC
  4. Re: I have bought a new (02) Passat
    May 2010
    Tregarth UK
    I will be awaiting a phone call tomorrow as I contacted them on the way home, I will most definitely need a free loan car! Thanks!
  5. Re: I have bought a new (02) Passat
    May 2010
    Tregarth UK
    The above suggestion by Toonmania is happening on Tuesday, I wanted them to pay a VW garage local to me to sort it, but not possible, so On Tuesday I drive my car back to Morecambe, they give me a polo, I then drive to Derby as I have uni there the next day, and then probably back to Morecambe to give them back their car on Thursday and hopefully retrieve mine to drive back to North Wales! Not sure I'll actually want to drive anything for a few days afterwards!
  6. Re: I have bought a new (02) Passat
    May 2010
    Tregarth UK
    Twas the pesky N75 valve that caused the problem, all fixed now, was a bit smokey for a bit, but that soon cleared with some heavy right footedness. I ended up having a 2012 Golf Plus, can't see the point of it myself, but I did like the cruise control. My local VW garage quoted £190 fitted to have it retrofitted, does that seem like a good price? I would be very wary of asking some of the local garages to do it, and the auto electrician I know is a bit of a butcher.
  1. Please Help Just bought a Passat
    By worker99 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-03-2009, 03:41 PM
  2. We just bought our first Passat!
    By lindylou in forum New Member Introductions
    Last Post: 28-02-2009, 09:08 PM
  3. Please Help 02 Passat just bought and doing something crazy please help!
    By stevieB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-10-2008, 01:15 PM
  4. Bought a Passat, got a few questions...
    By maddox in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-07-2007, 10:47 PM
  5. hello all, I just bought s/h passat
    By stevebrown in forum New Member Introductions
    Last Post: 07-05-2007, 01:27 PM
