Thread: Towbar install goes a bit wrong - need help coding module 34 level control
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Towbar install goes a bit wrong - need help coding module 34 level control
    Oct 2005
    Coding instructions for the Westfalia electrics kit on an A7 are here - http://www.westfalia-automotive.de/f...391101-007.pdf
    Adjusting the coding The AM code required can be found in the “coding supplement” on the Audi dealer portals (including ServiceNet).
    – Connect a suitable vehicle diagnostic, testing and information system to the vehicle via an online connection, e.g. the vehicle
    diagnostic, testing and information system -VAS 5051B-.
    – Select (Functions and Components) ((Funktions und Bauteilauswahl)).
    – Select the “Direct input of AM code for vehicle alteration” (“Direkteingabe AM-Code für Fahrzeugumbau”) testing programme
    from within Action Management (AM).
    – When prompted, enter the corresponding code (050 200).
    – Code the control unit in the self-diagnosis using the VAS tester:
    • 69 trailer function
    o 008 Codierung
    ƒ Masterbyte-Index (Hex-Code):
    0. ...
    1. 09 -> 00
    2. 08 -> 00
    3. ...
    4. ... etc.
    – Call up the fault memory of all control units and delete the “Undervoltage” (“Unterspannung”) fault as necessary.
    – Test towing functions using a suitable tester (with load resistors) or a trailer.
  2. Re: Towbar install goes a bit wrong - need help coding module 34 level control
    jbanfie Guest
    Hi Sam,
    Yes that's the printed booklet that comes with the towbar, the coding it refers to is that of the trailer module number 69. I have the issue with module 34.
    After about 6 phone calls, and some sterling work, no one actually knows the coding for an Air Suspension (J197) module on an A7, so I'm off to SP Diagnostics (PF Jones got them to call me) tomorrow and they are going to plug me into VAS for free, as they want to know how to code the air suspension for future reference.
    support@ross-tech have given me a pretty good steer too although they do not have a complete coding for the module either - I'll tell all tomorrow, but it's safe to say the problem of coding a towbar on an air suspension A7 is solved.
  3. Re: Towbar install goes a bit wrong - need help coding module 34 level control
    jbanfie Guest
    Right, so I spent nearly 3 hours at SP Diagnostics and we recoded the car using VAS to install the tow bar.
    The correct coding for the air suspension module is 008001, with bit 1 of byte 2 (0,1,2) being used to indicate the tow bar is fitted.
    However, the VAS stuff also coded:
    The rear electric boot hatch
    The parking sensors
    The adaptive headlights
    I think it also changes the rear lights so if you put the fog lights on, it doesn't light them on the car, just the trailer, then you don't get a load of red light reflected off your caravan! I'm going to test this.
    The long and short of it is that currently the after market tow bar fitters haven't caught up with new Audi technology.
    PF Jones are definitely honest people, and the Westfalia towbar is very good, I'd get the coding done at an independent Audi Specialist who has the VW Audi VAS system, and not pay the £70 coding to PF Jones until the Westfalia Coding unit is improved.
    0 2 0
  4. Re: Towbar install goes a bit wrong - need help coding module 34 level control
    May 2022
    Argyll
    This has happened to me with my install, many thanks for posting.
  1. Question Need help coding in handbrake control module
    By lpm150689 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2012, 05:12 PM
  2. Help ABS coding after DIS/Cruise install
    By philfingers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-02-2011, 01:01 AM
  3. Control Module Coding?
    By Zeb in forum South West England
    Last Post: 11-05-2010, 03:17 PM
  4. Bluetooth Kit Install and Coding
    By snight123 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-11-2009, 05:47 PM
  5. Towbar install - Do I need a relay?
    By ::SPG:: in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 13-08-2008, 08:14 PM
