Thread: DIY: LED strip DRLs within halogen headlight housings
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. DIY: LED strip DRLs within halogen headlight housings
    Sep 2012
    Liverpool
    I know this isn't going to be to everybody's tastes, I myself will be looking for some whiter/brighter LEDs in the future but I like the way it's turned out so far.
    Here's some pictures of the finished job:
    First you are going to need the LED lamps to swap the existing halogen DRL/sidelights these can be found on eBay by searching for "P13W Chevy Camaro LED" (I don't want to promote any particular seller), you will need 4 in total, a picture of the ones I used can be seen below.
    Use a hole cutter to cut out the circular blanks covering the DRL and sidelight bulbs, A and B, this will reveal the two lamps that need changing, simply unplug and swap with your new LED lamps, to seal the holes you can buy rubber seals (same as the ones covering the holes for your headlights) from your dealer (seen in 2nd picture below).
    2 0 0
  2. Re: DIY: LED strip DRLs within halogen headlight housings
    Sep 2012
    Liverpool
    Now it's time to start on the LED strips, for this you will need to remove the lens from the housing, to do this i used a heat gun on medium heat and run it up and down the seal for approx. 3-5 min until I was able to pull the lens from the housing.
    Once you have the lens and the housing separated you can start to install your LED strip, again a simple search on eBay will bring up a lot of sellers offering these.
    I used the double sided tape provided with my LED strip to attach it to the housing in the shape I wanted, I then passed the cable through to the back of the housing and out of the hole I cut out earlier (this is the hole at the back of the unit and not the one on the bottom), the lamp/bulb holder that is visible through this hole is the one I jointed onto (DRL).
    Being an electrician I had a load of crimps knocking about which I used to joint the LEDs onto the DRL feed (sorry I have no pictures of this but you can see in the third picture of this thread how I've jointed the cables) you need to splice into the cables before they enter the lamp/bulb holder and attach your LED strip cables to these.
    *Note LEDs unlike normal lamps will not work with reversed polarity, so you need to make sure you get the + and - cables the right way around for the LED strip to work, if it doesn't simply reverse the cables.
    To re-seal the lens to the housing use the same method in reverse, offer the lens up to the housing and heat the sealant with the heat gun to bond them together, then allow to cool.
    Your all done, re-fit the headlights to the car plug in the adapter and away you go, there are no faults codes thrown up by this install.
  3. Re: DIY: LED strip DRLs within halogen headlight housings
    Sep 2012
    Liverpool
    I've just ordered some brighter/whiter LED strips along with amber LED strips for my indicators, hopefully they'll be here for the weekend as I'm planning a more OEM looking install, watch this space!
  4. Re: DIY: LED strip DRLs within halogen headlight housings
    Oct 2010
    Midlands
    I fitted the LED bulbs about a year ago, gotta say I wasn't too impressed as the light output was much duller the the halogen DRLs, also the light looked distinctively blue.
    I also tried the LED strip method but with larger LEDs, I fitted them in front of where the DRL bulbs would sit, unfortunately the plastic lense at the bottom obscured them giving a not very appealing effect.
    Can't wait to see how yours look, given that they're fitted above.
  5. Re: DIY: LED strip DRLs within halogen headlight housings
    Dec 2008
    What´s the point of doing all this work to eventually fit leds that are half as powerfull as the original drl??? you´re missing the main point here:drl are to be visible in daylight, what you need is a type of led between 4000-5000k colour (like Audi´s OEM equipment) and over 300 Lumens per led bulb so as to be visible
    A4 B8 Avant TDI from Spain!
  6. Re: DIY: LED strip DRLs within halogen headlight housings
    Oct 2010
    Midlands
    Quote Originally Posted by jabicho View Post
    For me it was simply because the stock DRL/Sidelamp bulbs were so damn yellow, which really detracts from the look of any modern day car. Even next to cheap H7 Headlamp bulbs they show up as dirty old yellow (rather like the Mk1 Mondeo lamps used to go).
    I would have been happy to simply replace them with a clearer whiter bulb, but nobody makes them, there seems to be only one type and they are around £20 each!, and there's four on the car.
    I looked at replacing the lamps with bi-xennons with the LED DRLs but you have to change the headlamp units + ballasts + a new bumper with washer jets is needed. Too much cost and hassle.
    So I gave the standard LEDs a go just to see if it would feasable if you get the right kind of LEDs. As it didn't work out I refitted the original DRL bulbs, but always have them switched off now. It makes me cringe whenever I see them on any A4 or A3, they look so awfull.
  7. Re: DIY: LED strip DRLs within halogen headlight housings
    Oct 2013
    Romania
    any pictures with the final look?
  8. Re: DIY: LED strip DRLs within halogen headlight housings
    46 Post(s)
    Quote Originally Posted by Quade View Post
    First 2 pictures in the post.
  9. Re: DIY: LED strip DRLs within halogen headlight housings
    Sep 2013
    leatherhead, UK
    OK can't argue that brighter is better. But thanks Scott_Fitz for the post, I'm sure many of use who have the early halogen DRLs are hankering after the full LED spec'd light set, but sadly can't afford to get the whole Xenon package. If you know of a better more appropriate LED bulb that meets your quoted criteria could you let us know? Or for that matter since this is now quite a common upgrade has anyone come across better LRD bulbs for this fix?
  10. Re: DIY: LED strip DRLs within halogen headlight housings
    Oct 2013
    Romania
  1. B7 Halogen - Bi Xeneon or Xenon headlight how can you tell which you have
    By ihs61 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-11-2011, 09:52 AM
  2. Facelift LED drls
    By SatsQ7 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 08-10-2010, 10:52 AM
  3. Possible to fit LED strip to Xenon headlights?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 24-02-2010, 03:38 PM
  4. VW Accessory LED DRLs for Scirocco???
    By Hogwarty in forum Scirocco - 2008-
    Last Post: 05-05-2009, 09:00 AM
  5. Non LED DRLs
    By Ramon959 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-01-2009, 11:12 PM
