Thread: Golf TDI GT SPORT BKD won't start when stood for over a day?
Results 1 to 9 of 9
  1. Question Golf TDI GT SPORT BKD won't start when stood for over a day?
    Apr 2007
    Devizes
    Hi all, looking after my sister's Golf while she's away in NZ. My first time working with diesel so go easy on me!
    When I first went to pick the car up a month ago it had stood for a week and wouldn't start. RAC got it going with easystart, switched engine off then started again fine straight away. Been driving it fine since then with no probs, engine runs fine hot or cold, fast or slow (but mostly fast!) If I've noticed anything it's that it takes one or two seconds cranking for it to start but I thought that might just be a 'diesel thing'? but it always has started, until yesterday, had only been stood for a day and cranking it until the oil pressure warning came on but no start. Easy start got it going, switched it straight off then straight on again, started fine. Same again this morning, but obviously can't be good using easystart every morning!!! Haven't checked for fault codes today as Mrs Sly has taken it to work but there were none following the previous time. I knew I should have looked into this sooner as these things never get better on their own do they but here we are!?
    What's going on then? I seems that if the car stands for a day then the fuel is draining back out of the engine and there isn't a head of fuel there to start it, nor is simply cranking it getting the fuel back in there? I did replace the fuel filter when I got it last month when I did the oil too, yukky sludge! I've searched the forums and most people seem to be having issues starting when warm, not cold. Someone did say that the flywheel needs to reach a certain speed before the ecu will inject fuel, it does seem to turn over quick enough but could a fresh battery or starter sort me out? Don't notice any difference in cranking speed between successful and non-successful starts. Should it be starting instantly on the button?
    Ignore the signature below, this is a manual 1k1 2.0l TDI sport 103kw with a BKD engine and just over 100k miles. I go away for six weeks in a couple of days so would like to leave it 'working' for Mrs Sly while I'm away so any help will be greatly appreciated.
    AUDI A3 1.8T 2001 X AUM AUTO LHD DENTS DIRTY-CARPETS!
  2. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Up North
    I was told by an RAC technician that the minimum cranking speed was 800rpm before it will squirt the juice in. The value might be wrong (I'm old and forget stuff) but the principle is the same.
    A poor battery might trip over this minimum and let you down, but this is usually a cold weather problem, not this time of year. You could always try a battery charger to give it a top up before you spin it over and if this is a reliable solution then it might be worth getting the battery drop tested. A weedy starter is more difficult to diagnose but usually the difference in sound is much more noticable than for a slightly limp battery.
    he other option is to wait 3 months and the bad weather will either eliminate this as a cause or confirm it.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  3. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Sep 2008
    chester
    17 Post(s)
    The bkd and others can suffer from warm starts,but cold is usually ok.your analysis is probably ok fuel draining back,test it by parking nose down if you can.try disconnecting the fuel supply and cycle the ignition see if any fuel comes out.
  4. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Apr 2007
    Devizes
    Quote Originally Posted by nevo View Post
    Cheers, I'm away for six weeks now but I'll try that when I get back if she's still having problems getting going in the mornings. (The car, not the missus!)
  5. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Aug 2011
    Meath
    No return valve as close to the tank as you can get it
  6. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Apr 2007
    Devizes
    Quote Originally Posted by paulkennedy View Post
    What, there is one or I should fit one?! I think I read that there might be a NRV in the dual pump but not sure if that's the case on this model?
  7. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Aug 2011
    Meath
    Sorry, I hate typing, fit one near the tank. they cost about 2 quid and you're guaranteed there's a filter full of diesel and 5 feet of pipe full of diesel, enough to start any car. If that doesn't work you lost 2 quid, that's still cheap diagnostics!
  8. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Aug 2011
    Meath
    I just noticed it's a BKD engine. Do you hear a hissing/squelching sound when you turn on the ignition?
  9. Re: Golf TDI GT SPORT BKD won't start when stood for over a day?
    Oct 2012
    Northants
    Thats what I was thinking, I had a customer once who had similar issues. I replaced a blown fuse and the in tank fuel pump started working again, no more bad starts ;-)
  1. Please Help Golf mk5 bkd engine misfire on tickover 2.0 gt tdi
    By Ianr703 in forum Golf MK5 - 2004 - 2009
    Last Post: 18-11-2013, 12:11 AM
  2. Replies: 1
    Last Post: 16-09-2011, 04:08 PM
  3. Golf Tdi 2.0 BKD shuddering on hot idle
    By Bakers VW in forum 2.0TDi - Engine
    Last Post: 22-07-2011, 11:41 AM
  4. Golf TDI BKD Wont rev and hesitates??
    By nchapp77 in forum Golf MK5 - 2004 - 2009
    Last Post: 11-04-2011, 05:49 PM
  5. How to change Glow Plugs 2.0 TDI Sport BKD
    By jennion in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-08-2009, 02:11 PM
