Thread: Fault - 00810 - Sensor 1/2 for Brake Pressure
Results 1 to 10 of 10
  1. Fault - 00810 - Sensor 1/2 for Brake Pressure
    Apr 2011
    Reading, UK
    Hi All
    Yesterday I started my car from cold and after releasing the electronic parking break I was faced with the engine management light (Parking Brake malfunction please refer to manual). When I got back home I did a VCDS autoscan the following errors were witnessed. Please ignore the Digital radio fault as I have recently upgraded my factory RCD300 to RCD510. I have not done any other modifications. Thank you for reading and as much help would much appreciated
    Self-Diagnosis Log
    Sunday,09,September,2012,13:54:58:46862
    VIN: WVWZZZ3CZ6P052785 License Plate:
    Mileage: 211930km-131687mi Repair Order:
    Chassis Type: 3C0
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 53 56 7D
    VIN: WVWZZZ3CZ6P052785 Mileage: 211930km/131687miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    VCDS
    Self-Diagnosis Log
    Page 2
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 A HW: 03G 906 018 A
    Component: R4 2.0l PPD1.1 9723
    Revision: --H01--- Serial number: VWZCZ000000000
    Coding: 0000078
    Shop #: WSC 00477 210 91526
    VCID: 234EEDD2DD8FEE04
    2 Faults Found
    18060 - Please check DTC Memory of Transmission Controller
    P1652 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 62
    Mileage: 211928 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:43:16
    Freeze Frame:
    RPM: 1312 /min
    Text: 24 Nm
    Speed: 0.0 km/h
    Text: 0.0 %
    Voltage: 12.66 V
    Bin. Bits: 00000001
    Bin. Bits: 00000000
    18061 - Please check DTC Memory of ABS Controller
    P1653 - 008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 62
    Mileage: 211928 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:43:21
    Freeze Frame:
    RPM: 832 /min
    Text: 64 Nm
    Speed: 26.0 km/h
    Text: 0.0 %
    Voltage: 14.01 V
    Bin. Bits: 00000100
    Text: 248 Nm
    Readiness: N/A
    VCDS
    Self-Diagnosis Log
    Page 3
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 042 F HW: 02E 927 770 AE
    Component: GSG DSG 070 0933
    Revision: 04507000 Serial number: 00000507110400
    Coding: 0000020
    Shop #: WSC 00028 028 00001
    VCID: 1628C4061EDD8BAC
    No fault code found.
    Address 03: ABS Brakes Labels: 3C0-614-095-C2.lbl
    Part No SW: 3C0 614 095 N HW: 3C0 614 095 N
    Component: ESP 440 C2 H015 0001
    Revision: H015 Serial number: 0657913248
    Coding: 0013605
    VCID: 2D5A0BEA8B4B2874
    1 Fault Found
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 103
    Mileage: 211928 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 12:43:16
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 DF
    Component: Climatic PQ35 090 0505
    Shop #: WSC 00000 000 00000
    VCID: 6BDEC5F275DFE644
    VCDS
    Self-Diagnosis Log
    Page 4
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000001841189
    Coding: 00880F0700041A00000A00000F000000000859435C
    VCID: 2A5000F6BAA53F4C
    Part No: 3C2 955 119
    Component: Wischer VW461 012 0503
    Coding: 00065493
    Shop #: WSC 00028
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 F HW: 3C0 909 605 F
    Component: 02 AIRBAG VW8 029 2421
    Revision: 08029000 Serial number: 0039USFCV6PU
    Coding: 0012338
    VCID: 2952FFFABFA33454
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 A HW: 3C0 953 549 A
    Component: Lenksäulenmodul 005 0010
    Revision: 00005000 Serial number: 3C5953507A
    Coding: 0001003
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 A HW: 3C0 920 960 A
    Component: KOMBIINSTRUMENT VD1 3930
    Revision: V0013000 Serial number: 00000000000000
    Coding: 0007405
    Shop #: WSC 01158 210 184362
    VCID: 2142E7DAC793FC14
    VCDS
    Self-Diagnosis Log
    Page 5
    Address 19: CAN Gateway Labels: 3C0-907-530.lbl
    Part No SW: 3C0 907 530 Q HW: 3C0 907 951
    Component: J533 Gateway H13 0172
    Revision: H13 Serial number: 3620P10A040182
    Coding: FD801F16000202001003
    VCID: 2F6611E281475A64
    Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
    Part No SW: 3C0 959 433 H HW: 3C0 959 433 H
    Component: IMMO 038 0364
    Revision: 00038000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    Part No: 3C0 905 861 C
    Component: ELV 023 0350
    3C0905861C ELV 023 0350
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
    Part No: 1K0 959 701 K
    Component: Tuer-SG 024 2366
    Coding: 0000693
    VCID: 366824867E1D6BAC
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 J
    Component: EPS_ZFLS Kl.5 D04 1606
    VCID: 336E1D926D6F7E84
    VCDS
    Self-Diagnosis Log
    Page 6
    Address 46: Central Conv. Labels: 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 038 0453
    Coding: 01910A0801860E763804941570085BCE103880
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 3C0 951 171 A
    Component: Neigungssensor 002 0508
    Component: Innenraumueberw.002 0508
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
    Part No: 1K0 959 702 K
    Coding: 0000692
    VCID: 37762982791792A4
    Address 53: Parking Brake Labels: 3C0-907-801-53.lbl
    Part No SW: 3C0 907 801 B HW: 3C0 907 801 B
    Component: EPB VC8HC001 013 0001
    Revision: 013
    Coding: 0000012
    VCDS
    Self-Diagnosis Log
    Page 7
    Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb
    Part No SW: 3C8 035 195 G HW: 3C8 035 195 G
    Component: Radio RCD510 050 0207
    Revision: 00000001 Serial number: VWZ1Z3L6697130
    Coding: 01000200020005
    Shop #: WSC 01357 011 00200
    VCID: 2C5C06EEB051217C
    1 Fault Found
    02877 - Digital Radio Antenna (R183)
    007 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100111
    Fault Priority: 5
    Fault Frequency: 47
    Reset counter: 104
    Mileage: 208262 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:12:58
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
    Also I include the Group 004 log,
    Address 03: ABS Brakes (3C0 614 095 N)
    15:37:27 Group 004
    -11.86° Steering Angle Sensor (G85)
    -0.82 m/s^2 Transverse (G200) Acceleration
    -0.12°/s Rotation Rate (G202)
    -0.389 m/s^2 Longitudinal Acc. Sensor (G251)
    Best Regards,
  2. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Apr 2011
    Reading, UK
    any help guys?
  3. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Oct 2005
  4. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Apr 2011
    Reading, UK
    Hi Sam
    Thanks for the reply. Do you know where this sensor is located (00810 - Sensor 1/2 for Brake Pressure) I have a vw passat b6?
  5. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Oct 2005
    Do you have any other faults at all?
    There is a common issue with the ABS/brake pressure switches failing and a repair kit has been issued.
    Have a look through this forum for posts that mention "G201"
  6. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Norfolk
    I may be wrong but I don't think there is a brake pressure sensor that can be replaced on the passat B6. I think it's integrated into the ABS unit. Crasher may know for sure.
    O.P. Use vcds to read the pressure live data from the abs, block 005 I think. With no foot on the pedal you should get a constant zero. I suspect you will see an up and down value rather than constant zero. If this is the case you need a new pump. eek!
  7. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Oct 2005
    Quote Originally Posted by martin1810 View Post
    Depending on the ABS unit, the switch is either a part of it, or fitted to it externally. I thought there was a repair kit for most models now as it was quite a big issue when they started going wrong. It was around the £200 mark last time this came up. Things may have changed since then though.
    If it is a new pump that's needed, there are various outfits who will refurb/adapt the old one for a lot less than the price of the £1k+ replacement.
  8. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Apr 2011
    Reading, UK
    Hi Guys
    Thanks to all that have responded.
    So as mike suggested, I cleared the codes, disconnect battery and touch cables together for 30sec or so. reconnect drive and see what happens. The fault came back this morning,
    Fault - Instrument cluster - Beep sound followed by the following lights and message on MDF, Coil light flashing - Parking symbol alight (round circle with a letter P and a line though it) - ESP symbol alight, and message displayed "Parking Brake Fault please refer to manuals"
    VCDS scan shows the following faults,
    Self-Diagnosis Log
    Wednesday,12,September,2012,11:17:35:46862
    Mileage: 211950km-131699mi Repair Order:
    Chassis Type: 3C0
    VIN: WVWZZZ3CZ6P052785 Mileage: 211950km/131699miles
    02-Auto Trans -- Status: Malfunction 0010
    53-Parking Brake -- Status: Malfunction 0010
    VCDS
    Self-Diagnosis Log
    Page 2
    Coding: 0000078
    2 Faults Found
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 68
    Mileage: 211955 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:06:47
    Freeze Frame:
    RPM: 1408 /min
    Text: 40 Nm
    Speed: 0.0 km/h
    Text: 0.0 %
    Voltage: 12.66 V
    Bin. Bits: 00000001
    Bin. Bits: 00000000
    Freeze Frame:
    Fault Status: 11101000
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 68
    Mileage: 211955 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:06:52
    Freeze Frame:
    RPM: 1056 /min
    Text: 0 Nm
    Speed: 23.0 km/h
    Text: 0.0 %
    Voltage: 14.46 V
    Bin. Bits: 00000100
    Text: 208 Nm
    Readiness: N/A
    VCDS
    Self-Diagnosis Log
    Page 3
    Coding: 0000020
    1 Fault Found
    18255 - Please check DTC Memory of ABS Controller
    P1847 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Reset counter: 1
    Mileage: 211955 km
    Time Indication: 0
    Coding: 0013605
    1 Fault Found
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 2
    Reset counter: 67
    Mileage: 211955 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:06:47
    VCDS
    Self-Diagnosis Log
    Page 4
    Coding: 00065493
    Shop #: WSC 00028
    Coding: 0012338
    Coding: 0001003
    VCDS
    Self-Diagnosis Log
    Page 5
    Coding: 0007405
    1 Fault Found
    02649 - Digital Radio Tuner
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 104
    Mileage: 211936 km
    Time Indication: 0
    VCDS
    Self-Diagnosis Log
    Page 6
    Coding: 0000693
    Coding: 0000692
    VCDS
    Self-Diagnosis Log
    Page 7
    Revision: 013
    Coding: 0000012
    1 Fault Found
    01316 - ABS Control Module
    013 - Check DTC Memory - MIL ON
    Freeze Frame:
    Fault Status: 11101101
    Fault Priority: 3
    Fault Frequency: 99
    Reset counter: 69
    Mileage: 211952 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:06:47
    Freeze Frame:
    Voltage: 14.39 V
    Count: 236
    1 Fault Found
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 52
    Reset counter: 109
    Mileage: 208262 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:12:58
    VCDS
    Self-Diagnosis Log
    Page 8
    I also too a reading of the measuring block,
    11:20:07 Group 005
    0.00 bar Brake Pressure Sensor
    SteerAng lnit Steering Angle Sensor Condition
    OFF ASR Button
    BLS OFFf Brake Light Switch (F)
    Wednesday,12,September,2012,11:22:45:46862
    11:22:42
    4.38° Steering Angle Sensor (G85)
    -0.74 m/s^2 Transverse (G200) Acceleration
    I'm getting zero on the Brake pressure sensor could this still be a ABS pump fault??? I have made some enquires with companies that recon they have all said that they can not recondition the passat ABS pump only golf versions. (so no repair kit available for mine). I also, phoned vw and they said no repair kit available for mine, only a new one at ...........£1500 ex-vat. I would really like to be sure that it is the ABS unit that has failed and not something simple (like a switch/sensor). Help?
    Kind Regards,
  9. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Oct 2005
    Ouch!
    Starting with the fault code that remains from the original post have you done what the Ross Tech Wiki suggests?
    18061/P1653/005715 - Ross-Tech Wiki
    Possible Solutions
    Check Brake Electronics Control Module (J104) for Fault Codes
    VCDS > Select > 03 - Brake Electronics > Fault Codes - 02
    The new code - 18255/P1847/006215 - Ross-Tech Wiki - suggests the same procedure too
    Possible Solutions
    The ABS code - 01316 - Ross-Tech Wiki - has a few things to try too.
    IANAM (I am not a mechanic) but it's all pointing towards a buggered ABS pump.
    Do the above things first though and report back.
  10. Re: Fault - 00810 - Sensor 1/2 for Brake Pressure
    Norfolk
    You need to run more tests on the brake pressure sensor. If it is 0.0 bar at idle with no pedal press, what is it when you press the pedal. If the pressure is not going up and down when the brake pedal is pressed/released then the sensor is not working and the pump needs replacing.
    e.g.
    11:20:07 Group 005
    OFF ASR Button
    So pressure is 0.00 Bar when Brake Light Switch is off.
    What is brake pressure sensor reading with brake Light Switch On?
    You will need to do this a few times to get several brakes on/off results for comparison.
  1. A3 01435 - Brake Pressure Sensor 1 (G201) Fault and others
    By grimzz in forum VCDS - Help Requests
    Last Post: 30-10-2011, 05:07 PM
  2. Brake pressure sensor fault
    By if11677 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-11-2010, 12:49 PM
  3. A/C high pressure sensor fault
    By badass76 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2010, 06:13 PM
  4. Question esp - brake pressure sensor
    By stumpjumper in forum Leon
    Last Post: 23-10-2009, 10:10 AM
  5. Please Help Brake switch and brake pressure sensor issue??
    By P.M.G in forum Audi A3 - Archive Topics
    Last Post: 07-02-2009, 06:20 PM
