Thread: how to bypass / change immobiliser ? part 3C0905861J
  1. Unhappy how to bypass / change immobiliser ? part 3C0905861J
    Sep 2012
    france
    when trying to start my car, I have an error "Steering column locked, go to garage". By reading on the net, I assume this module is faulty and can be replaced separatly without the whole steering column.
    But my issue is that my car is totally blocked (impossible to trigger ignition) thus I'd like to either find a trick to bypass the first error or change the part my self. (serial# 3C0905861J plus N 91023802).
    Assuming I change the controler, what are the next steps ?
    - would I be able to restart the engine and drive ?
    - should I do a reset with a diag ?
    - I read that a reprog of the keys should be done. Why ? Is it risky and easy ? how to do that ?
    thx
    JD
  2. Re: how to bypass / change immobiliser ? part 3C0905861J
    Jun 2008
    Dealer only fix i'm afraid because of coding required.
  3. Re: how to bypass / change immobiliser ? part 3C0905861J
    Norfolk
    Quote Originally Posted by jdrulez View Post
    thx
    JD
    You probably just need a new steering lock which is about £60 but you can't code it in without the SKC and VW won't tell you it. In theory the skc can be extracted by an aftermarket program but I haven't seen anyone do this and change a steering column lock. So far the only place is a dealer and they charge about £250 to do it plus the lock.
    Some more info is available here: B6 STEERING FAULT - PASSAT
  4. Exclamation Re: how to bypass / change immobiliser ? part 3C0905861J
    Sep 2012
    france
    thanks, I'm impressed by the details
    however I still don't know if after replacement of the component, why coding is necessary
    I'll try first a spray cleaner...
    here are my faults codes (in case it rings a bell)
    02823 - Requirements for Locking the Steering Column Lock not met
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 7
    Fault Frequency: 14
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    02827 - Wake-Up request via ESP
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 11
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    02861 - Electronic Steering Column Lock Check Sum Error
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 185517 km
    Time Indication: 0
    Date: 2012.08.29
    Time: 22:22:21
    02815 - Steering Column Lock; Supply Voltage for Locking Motor
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 4
    Fault Frequency: 109
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    02817 - Steering Column Lock; Enabling Wire from Steering Wheel Electronics
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
  5. Re: how to bypass / change immobiliser ? part 3C0905861J
    Norfolk
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 14
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 11
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 88
    Mileage: 185517 km
    Time Indication: 0
    Date: 2012.08.29
    Time: 22:22:21
    These two are a little odd.
    Freeze Frame:
    Fault Priority: 4
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 2
    Reset counter: 93
    Mileage: 0 km
    Time Indication: 0
    Some of those faults look like someone has been playing with the controllers/wiring. Clear everything and see what comes back. The steering column lock 'knows' what the skc/vin is and this must be taught/adapted to the new lock and only VW can do it. If it is a faulty lock, you should get it working with some contact cleaner.
  1. Please Help GTi immobiliser bypass
    By andrew@tuneup.f in forum Golf MK3 - 1993 - 1999
    Last Post: 11-02-2009, 04:54 PM
  2. Key barrel change - Immobiliser problem I Think! Any ideas?
    By arch_pieman in forum Chat - Anything with wheels
    Last Post: 16-12-2008, 10:49 PM
  3. Replies: 2
    Last Post: 22-09-2008, 08:47 AM
  4. Please Help immobiliser Problems - immobiliser bypass?
    By MC_BLADE in forum Audi A3 - Archive Topics
    Last Post: 31-07-2008, 07:35 PM
  5. immobiliser beeps on battery change
    By mike baker in forum A8 - S8 - V8
    Last Post: 31-03-2008, 09:00 PM
