Thread: Help. engine light, auxiliary coolant pump
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
  1. Re: Help. engine light, auxiliary coolant pump
    #21
    Jun 2011
    Drogheda Ireland
    Quote Originally Posted by gupsterg View Post
    Sounds about right... I would have/get some coolant while your picking up your parts...
    Thanks Gupsterg. Hope to have the pump today, I'll get it fitted asap and report back
    VW CC GT 177 DSG
    1 1 0
  2. Re: Help. engine light, auxiliary coolant pump
    #22
    Have you checked the connector and measure the resistance. Regards Peter
  3. Re: Help. engine light, auxiliary coolant pump
    #23
    Jun 2011
    Drogheda Ireland
    Quote Originally Posted by Peter D View Post
    Hi Peter,
    I didn't get to measure the resistance. I was told I could end up damaging part of the ecu by using the multi meter. So decided against it.
    The pump arrived today with a new bracket, €136. Fitted in half an hour. Started the car, plugged in the vcds to the ecu and cleared the fault, started the car checked for the code again and didn't appear back since. So happy to have it sorted now
    VW CC GT 177 DSG
    1 1 0
  1. V5 Auxiliary Water Pump question...
    By deserthawk in forum Bora - 1998 - 2005
    Last Post: 26-01-2017, 05:26 PM
  2. Engine management light + coolant sensor
    By Mcpickering in forum Golf MK4 - 1999 - 2004
    Last Post: 25-10-2009, 10:21 AM
  3. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
  4. Auxiliary water pump replacement...
    By webchem in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-10-2008, 10:35 AM
  5. Engine Managment light-Coolant leak
    By pembo1976 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-09-2007, 07:23 AM
