Thread: door panel removal Fox 1.2
  1. Lightbulb door panel removal Fox 1.2
    Sep 2012
    Germany
    Hi there! PLEASE HELP!!! I'm that German girl who's trying to remove the door panel of my 2005 Fox 1.2. The first problem seems to be that plastic ring of the manual window crank, under which should be a springy ring I can get no purchase...while pushing the panel in a bit...is there a trick? do I need a special tool? screwdrivers won't do it...
    Now what I would like is a step by step detailed description how to remove this panel in order to check what broke or went wrong with my window manual winding mechanism...and hope I can buy some replacement parts for it somewhere without having to send to Brasil!
  2. Re: door panel removal Fox 1.2
    Nov 2012
    manchester
    hi there, im trying and failing to remove the window winder to get the door card off. Could you please tell me how you got it off, as trying to find info on the little fox is next to imposable. also what was wrong with the mechanism as mine is rely tight going up and down. thanks
  3. Re: door panel removal Fox 1.2
    Sep 2011
    Lurking over a keyboard ...
    Where window handle/crank is the spacer ie the plastic piece between window handle and door card must be removed by sliding it...
    Below image red/orange is handle... blue piece spacer...
  1. Door panel removal
    By john24susan in forum Golf MK6 - 2009 - 2013
    Last Post: 14-07-2012, 10:22 AM
  2. Interior door handle and door panel removal guide
    By sferg55 in forum Bora - 1998 - 2005
    Last Post: 19-10-2008, 09:59 AM
  3. VW Fox ... Beware of "bendy" door panel
    By routemaster in forum Polo - Derby - Lupo - Fox
    Last Post: 10-06-2008, 03:08 PM
  4. Knocking in side door/ door panel removal
    By AudiwantisanS3 in forum Audi A3 - Archive Topics
    Last Post: 04-03-2008, 06:06 PM
  5. Door panel removal - help??
    By DeeVee in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-07-2006, 03:45 PM
