Thread: Changing mk3 wing
  1. Changing mk3 wing
    Jul 2007
    I was wondering if changing the offside (drivers) wing was an easy job? Mine has rusted pretty badly and was thinking of replacing it myself. I know theres four bolts at the top of the wing and the plastic cowl has to come off from underneath the arch. Is there anything I need to be careful of? ie: wiring, pipes etc?
  2. Re: Changing mk3 wing
    Jul 2007
    I take it no has changed a wing here.....
  3. Re: Changing mk3 wing
    Mar 2007
    U-96
    Changing a wing, is a straightforward enough job. I would suggest carefully jacking up the driver's side (and placing on an axle stand), and removing the wheel to ease access though.
    Take care to jack from the exactly the right place (i.e. load bearing, not floor), and to put an axle stand on a main beam, not on the floor.
    With the wing off, use this oppurtunity to try and clear as much debris (leaves, twigs, mud ...) from the wing area, otherwise rust and rot may recurr.
    Ensure you feed the wing indicator light through the wing before mounting the wing.
    When replacing the new wing, put the nuts on loosely so that you can align the wing before tightening.
    You shouldn't have any major issues.
  1. Sat Nav or Wing and a Prayer?
    By prolfe in forum Chat - Anything with wheels
    Last Post: 02-08-2007, 11:36 PM
  2. Sharan wing mirror
    By iainherd in forum Touran - Sharan - Caravelle
    Last Post: 20-07-2007, 10:45 PM
  3. Polo 6n wing mirror
    By arryb in forum Polo - Derby - Lupo - Fox
    Last Post: 12-06-2007, 03:01 PM
  4. Wing Mirrors
    By bbb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-05-2007, 09:55 PM
  5. golf mk3 wing?
    By Maddoggolfface in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-11-2006, 08:04 PM
