Thread: Polo oil light on- but level fine
Results 1 to 8 of 8
  1. Polo oil light on- but level fine
    Bristol
    My Polo's been very slowly leaking oil for a while now, but it's within the supposed limits of 'normal' in the handbook. Normally, when the light comes on in the dash cluster (orange, not red) the level has just dipped below the lower limit. I always use VW 505 or 507 spec oil, and I'm servicing it annually but to longlife specifications. However, the light has started coming on when the level is fine. It came on today and the level was about halfway between the two markers on the dipstick. The wiring to the oil sensor looks fine, but I guess the sensor itself could be damaged, or the light could be something else. I don't have a code reader (anyone got one in Bristol?) but what should I look out for?
    The engine is an AZQ one- 1.2, 12v, 65PS. It's a 2002 9n, and done 130,000 miles, which I think is possibly heading towards the stage where it becomes very expensive to run...
    2002 Polo 9n 1.2 65PS. Basic but it's better than the train!
  2. Re: Polo oil light on- but level fine
    Colchester,Essex
    Best to read the fault codes,normally the oil level sensor,usually on the sump also check the wires to it have ho damage or open circuit.
  3. Re: Polo oil light on- but level fine
    Bristol
    Planning to get it code read, but it sounds unlikely to be anything too dangerous!
  4. Re: Polo oil light on- but level fine
    Colchester,Essex
    As I said usually oil level sensor.
  5. Re: Polo oil light on- but level fine
    Bristol
    Roughly how hard is that to replace?
  6. Re: Polo oil light on- but level fine
    Colchester,Essex
    Drain the oil,sensor out and a new one in,piece of cake.New oil if you like.
  7. Re: Polo oil light on- but level fine
    Bristol
    It's not far off a service, I'll do it then. I can put up with checking the oil levels more frequently until then. Am I right in thinking that if the light turns off, then there isn't a code stored though, and therefore it must be a level issue?
  8. Re: Polo oil light on- but level fine
    Colchester,Essex
    The code may (wouldn`t worry about it)stay but the light shouldn`t bother you again.
  1. Oil Min Light Error - Oil Level Sensor Fault (2006 2.0l TDi S-Line)
    By i_786_i in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 05-08-2012, 11:24 AM
  2. Oil level warning light on BUT oil level is correct!
    By VAGMAN2 in forum Golf MK5 - 2004 - 2009
    Last Post: 02-08-2011, 07:44 PM
  3. Checking Oil Level - Polo 1.4 16V 2003
    By Omni in forum Polo - Derby - Lupo - Fox
    Last Post: 25-02-2008, 07:30 PM
  4. Oil Level and yellow oil light
    By Trucypriot in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-10-2006, 01:53 PM
  5. Check coolant warning but level fine
    By brad1 in forum Archive posts
    Last Post: 28-07-2006, 02:37 PM
