Thread: Engine not firing.
  1. Engine not firing.
    Problem with wife's car, and she is getting grumpy! Please help.
    1999 Passat 2.3 v5 Engine AGZ.
    Drove home, parked, switched off, all good no problems.
    Tried to restart 2 hours later, turns over but doesn't fire, not a cough even. (normally starts every time, half turn of the crank).
    All other electrics seem to work ok.
    Code reader shows
    000668 Battery Power Voltage Supply Terminal 30 (0668)
    000282 Throttle Position Actuator V60 (0282)
    001314 Engine ECU (1314)
    000522 Engine Coolant Temperature Sender G62 (0522)
    I think the last is a red herring, temp gauge stopped working a year ago so a non OEM sender was fitted and has worked perfectly ever since, does the car know it's not genuine?
    I figure if the first three codes are related, I don't have a good voltage supply to the Throttle body, so the ECU is upset and won't let the engine fire?
    But where do I look?? and how do I test? Any pointers gratefully received.
    Many Thanks,
    Chris
  2. Re: Engine not firing.
    I had this problem. In my case it was due to the battery comparment in front of the windscreen flooding and causing wireing faults due to corosion. The drain holes for that chamber are conveniently place under the battery and under the brake servo. (Yes they use two in case one blocks).
    It requires wire tracing and patience.
  3. Re: Engine not firing.
    Quote Originally Posted by Sam Russell View Post
    Many thanks for your reply, I don't think that is the answer in my case. We have owned this car many years and I have always kept the pelham? drains clear (thanks to dire warnings of what happens if you don't).
    More checking has shown, Cam shaft (1) seen to turn through oil filler hole - Very good spark, so ignition electrics seem OK. - Spark plugs come out damp and smelling of fuel after turning engine over. Shouldn't ECU stop the injectors when it doesn't fire?
    With Fuel, a spark, and compression why doesn't it at least cough?
    Anyway, I've lost patience with it now. 160k miles, parking rash on a door, and it's age, I figure on a good day as a runner it's pretty worthless so I am using this as an excuse to buy "Madam" something newer. Hate letting it beat me but life's too short!
  4. Re: Engine not firing.
    Quote Originally Posted by motman View Post
    I think that is wise. Don't chuck good money at it.
  5. Re: Engine not firing.
    Jul 2010
    Brighton
    RIP poor Passat, maybe you have got some space to break it? as spare parts you could get around £1000 back on it just an idea
  6. Re: Engine not firing.
    Quote Originally Posted by Toonmania View Post
    Unfortunately no room, so it's got to go. replacement car arrives tomorrow, sad really, first time in over 20 years that we won't have a Passat.
  7. Re: Engine not firing.
    Jul 2010
    Brighton
    oh well just a thought, hope you are very happy with the new car though
  1. Please Help Engine hunting/Miss firing
    By ClarkyA3tdi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-07-2010, 10:08 PM
  2. Please Help Audi 80 2.0 16V ACE engine not firing
    By audi8016v in forum 80 - 90
    Last Post: 18-05-2010, 10:12 AM
  3. a4 2.8 30v engine not firing
    By idua777 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-04-2010, 09:07 PM
  4. Please Help 1996 golf gti engine not firing
    By golfan in forum Chat - Anything with wheels
    Last Post: 24-05-2008, 01:33 PM
  5. First Post - engine firing up query
    By mccourtmeats in forum Archive posts
    Last Post: 30-12-2007, 10:40 PM
