Thread: Oil change? Is a New sump plug and washer essential?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Oil change? Is a New sump plug and washer essential?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I would agree that in vehicles that have been serviced by some garages & non-caring owners who do not change the plug ,the chances of the plugs being dropped , not cleaned and not checked are quite high and I would guess that this is the reason why VW recommend them to be renewed. But for the careful owner who does all his own oil changes & has time to spend to clean and check plugs , renewal is not IMHO necessary.
    The majority of the damaged bruised/burred thread plugs cannot be seen easiily with the naked eye, it needs an at least a 10X eye glass to see it. In most screw manufacturing processes, completed screws are continually dropped onto each other causing thread damage. Unless special precautions are made in the process and each screw is protected in a similar fashion to that of spark plugs ( cardboard collar around the thread) , then damage, however slight, will occur.
    Skoda Octavia II SE 1.9PD TDI
  2. Re: Oil change? Is a New sump plug and washer essential?
    Dec 2014
    Germany
    I would recommend replacing the sump plug washer every time you perform an change the oil. I actually use a Femco oil drain plug, the plug only installed once and you don’t have to change the washer every time you perform an oil change. Besides this you avoid damage to the thread and to the sump itself. http://www.femcodraintechnology.com/
  3. Re: Oil change? Is a New sump plug and washer essential?
    Oct 2014
    Bristol
    Whenever I have to disturb a sump plug, I like to have a fresh washer to go back on - preferably a collapseable copper one.. very reliable sealing.
    But,
    Unless there is serious oil contamination (fuel, water, etc), I do an oil change by sucking it out through the dipstick. You won't get 100% out, but you don't get complete removal by bottom draining either. The solution to pollution is dilution... Much quicker to do this way, and you don't have to worry about sealing up the sump. Very clean method too....
    A6 2005 3.0 TDI Quattro Tiptronic - Only mod so far = Integrated DAB
    Octavia 1 2005 1.8 20v VRS - Rescue Project !
  4. Re: Oil change? Is a New sump plug and washer essential?
    Up North
    I got a free service on my wife's car at my local VW dealer. Long story, but it was by way of compensation. Anyway... picked the car up, drove home and noticed oil leaking on my drive. So I went back and they fixed it. Methinks my free service didn't include a new sump plug and more likely, the old one got dropped. I was absolutely on tenterhooks at the next (indie)service in case all they'd done was heave on a spanner until the drip stopped, I expected to end up with a new sump.
    Whoever decided to make the seal dependent on an aluminium thread is halfwit.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  5. Re: Oil change? Is a New sump plug and washer essential?
    Pembrokeshire
    22 Post(s)
    on these sump plugs that don't use a washer to seal, you can add a copper washer. this ends the problem once and for all. its a steel bolt thats tightened to 25nm, thats not tight at all, certainly not tight enough to damage a thread. the threads get damaged when people don't replaced it and try to stop it leaking, by overtightening it. add a copper washer and jobs done, a sump plug for life.
  6. Re: Oil change? Is a New sump plug and washer essential?
    131 Post(s)
    1973 Post(s)
    Quote Originally Posted by Teflon View Post
    The sump is made of aluminium to make the block more rigid but it has been a pain due to the thread failing and impact damage so now the sump is often two piece with an ally upper and stamped steel lower.
  7. Re: Oil change? Is a New sump plug and washer essential?
    #17
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Most modern VAG models have captive washers on the sump plug so you cannot fit a copper washer easily . On models with alum sumps the the sealing is done by the soft alum threads deforming to the steel plug threads.
  1. Sump plug washer
    By ihs61 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-06-2012, 10:40 PM
  2. Replies: 2
    Last Post: 10-04-2011, 08:54 PM
  3. Question sump plug
    By williamjack in forum Bora - 1998 - 2005
    Last Post: 05-10-2009, 07:01 AM
  4. Sump plug washer
    By Dunk in forum The Commercial Range
    Last Post: 25-07-2009, 11:18 AM
  5. Oil Drain Plug (or Sump) Removal Problem
    By Chromate in forum Golf MK3 - 1993 - 1999
    Last Post: 05-03-2008, 12:41 AM
