Thread: New buyer, Special Edition TFSI or TDI?
  1. New buyer, Special Edition TFSI or TDI?
    Mar 2009
    Hi there,
    Been lurking a while but now finally in a position to buy and been searching for a few weeks now for a good Avant Special Edition.
    Anyways I have my eye on 2 of the same year (07) and 1 is the petrol model and the other is diesel.
    I was leaning towards the diesel mainly down to MPG and almost put a deposit down yesterday until I started researching the car more and was shocked to see so many oil balancer shaft issues.
    It's already had the injectors changed due to the known issue with them but is the oil balancer shaft issue really a question of when rather than if?
    If it is that common and a certainty to fail why are so many owners out there sticking with them?
    So is this a no brainer and the petrol should be the only model to go for?
  2. Re: New buyer, Special Edition TFSI or TDI?
    Colchester,Essex
    Well injectors is a recall on 2.0 diesels and yes balance shaft has ruined some engines.TFSI is better economy though over normal petrol engines as they increased the rail pressure.When it comes to a balance shaft falure all your money saved on fuel will go into repairs in the best case or even more if the engine needs replacing so hard to suggest.1.9tdi is what I stick to.
  3. Re: New buyer, Special Edition TFSI or TDI?
    Aug 2009
    Near Lanark
    21 Post(s)
    depends on your mileage.
    higher mileage....look towards diesel.
    lower mileage....consider the petrol.
    audi petrol engines aren't the most economic around. my 2.0tfsi gets worse economy than my BMW 3.0Z4 used to get. Similar power output so I know the Audi engine is more highly tuned.
    I've had my 2006 Tfsi for almost 3 years. Spent hardly anything on repairs, passed last couple of MOTs without any work needing done and so far it's been a great car for me. I'd recommend one...especially a quattro if you get snow where you live. Quattro uses a bit more fuel in day to day use but come winter you just love it....even on normal tyres.
    A6 C7 Saloon 3.0Tdi Quattro S Line | 242bhp | Quartz Grey
    2016 Triumph Street Triple | 106bhp | Pearl White
    VCDS owner - Lanarkshire Area. PM Me if you need help.
  4. Re: New buyer, Special Edition TFSI or TDI?
    Dec 2010
    CD UK
    6 Post(s)
    I have the version with black optics and these have the BRD version of the 170PD engine which I believe is not one of those affected by the balancer shaft issue.
    Nevertheless, after scaring myself reading all the posts I decided that after living a year out of warranty on goodwill, I ought to cover myself with a good warranty from the end of year 4.
    I'm pleased to report that over a year on I've had no cause to claim for anythingwith Audi volunteering the injector replacement that applied to these engines.
    My MPG improved from under 40 to between 40-44 so I'm happy with the car and the outcome. The engine characteristics are a bit quirky particularly at low revs, but this is something you get used to and otherwise they,re rewarding especially with the reassurance of quattro like mine has.
  5. Re: New buyer, Special Edition TFSI or TDI?
    Mar 2009
    Cheers for the replies guys.
    i was under the impression all the PD engines had the oil pump issues? Just the BRB engines had a crappy plastic chain tensioner as well.
  6. Re: New buyer, Special Edition TFSI or TDI?
    Aug 2008
    Somerset
    Quote Originally Posted by fonz600 View Post
    Basically, yes. But the gear-driven ones give less hassle because they put less stress on the hex shaft.
    '07 A4 Avant 2.0PD 170 quattro s-line Special Edition and '94 T4 Westfalia California Club 2.4td fettled by ABT
  1. Revo remap done today on my 2.0 tfsi s line special edition via streetwise
    By trapster in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-07-2015, 03:52 PM
  2. Question 2008 1.9 TDI Special Edition
    By RodA in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-03-2015, 12:47 PM
  3. A4 2.0T Special Edition brakes
    By aberdeeneuan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-08-2011, 10:12 AM
