Thread: Just got an '02 A4 Wet carpets
Results 1 to 9 of 9
  1. Just got an '02 A4 Wet carpets
    Aug 2012
    West Yorkshire
    Hi guys, I am an A4 virgin and have just acquired a 2002, registered October. Is that a B6??
    Anyway, sweet car, runs nice, but wet carpets passenger side (Left hand)
    Where do I start looking please?
    Colin
  2. Re: Just got an '02 A4 Wet carpets
    Aug 2011
    Hornchurch
    Yes its a B6, the problem is Blocked Plenum Chambers, It is an Audi recall on certain aged and Model A4's, so contact your local dealer and if your car was part of the recall they will sort it out under warranty. If not use the search function on here and search Plenum Chamber and it will give you an in depth guide on how to unblock them
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  3. Re: Just got an '02 A4 Wet carpets
    Colchester,Essex
    i think b6 is similar to b5 so check blocked frainage where the battery sits and cracked pollen filter housing,dirt and leaves do block them..Hope that helps.
  4. Re: Just got an '02 A4 Wet carpets
    Aug 2011
    Hornchurch
    Quote Originally Posted by turpal View Post
    check blocked drainage where the battery sits and cracked pollen filter housing,dirt and leaves do block them
    This is known as the Plenum Chamber.
  5. Re: Just got an '02 A4 Wet carpets
    Aug 2012
    West Yorkshire
    Thanks guys. Just sucked about a gallon of water out! Will have to get battery out next and clear debris!!
  6. Re: Just got an '02 A4 Wet carpets
    Jan 2009
    Birmingham
    36 Post(s)
    To get battery out you will need a long 6mm Allen key when I had to change mine didn't have one had to drive around friends to see who had one just thought il let you know
  7. Re: Just got an '02 A4 Wet carpets
    Aug 2012
    West Yorkshire
    Thanks everyone. One job sorted! Just hope the electronics are OK!!!
    CP
  8. Re: Just got an '02 A4 Wet carpets
    Feb 2009
    Central convenience unit is under the carpet in the passenger footwell. Would advise you lift the carpet, remove the unit, open it and dry it completely.
    Walter
    Sent from my ASUS Transformer Pad TF700T using Tapatalk 2
  9. Re: Just got an '02 A4 Wet carpets
    Colchester,Essex
    Quote Originally Posted by wmccann View Post
    Walter
    as above
  1. Please Help-Carpets soaking wet !!!!!!
    By Reidy4862 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 18-02-2011, 09:24 PM
  2. Question Wet Carpets
    By Gary.Townend in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2010, 04:00 PM
  3. Help! Wet carpets
    By Simpsvag in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-03-2009, 12:04 AM
  4. Question Remove wet carpets.
    By Keith L. in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-01-2009, 11:26 PM
  5. A8 wet carpets
    By sdcoomber in forum A8 - S8 - V8
    Last Post: 15-03-2006, 05:38 PM
