Thread: Aircon/Climate Control
  1. Aircon/Climate Control
    Aug 2012
    Yeovil, UK
    My aircon doesn't seem to be blowing cold air, the fans kick in to cool it but no cold air comes out. Halfords tested it and the pressure didn't change between it being off and on.
    any thoughts?
    This is my first audi so am a bit clueless
    ps this is an A4 1.8 Avant, 1999
  2. Re: Aircon/Climate Control
    Nov 2006
    Sounds like a leak in the system. The air con pump shuts off when the gas has all escaped from the system. Your best bet (if you've made sure there is nothing more obvious such as a snapped belt or a fuse gone to the pump) is to get an air con specialist to refill your system with dye to check for leaks.
    I had the same problem and it was a leak in the pump seal. Pricey repair, alas I have no air con at the minute! Have seen a leak repair canister that you can fill the system with for sale in *********. Haven't heard of anyone using it though.
    VW CC. 2012 (facelift) TDI 140 Manual
    VW Polo 1.2 9n3 2006 - gone
    Saab 93 Aero 2.0T 256hp noobtuned 2004 - gone
    Audi A4 b5 1.8 auto non-turbo ADR (1996) - gone
  1. Question climate control blower failure/resistor pack/ control panel ?
    By ianmcneill in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-08-2011, 10:00 PM
  2. Question AirCon, Climatic, Climate Control
    By kimbie in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-07-2011, 06:05 PM
  3. aircon/climate control
    By bazwood in forum Touareg
    Last Post: 30-10-2009, 01:14 AM
  4. A4 B6 Aircon / climate control problem
    By aphilmor in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-03-2009, 10:43 AM
  5. Replies: 2
    Last Post: 08-08-2008, 10:53 PM
