Thread: VW Bora 1.6 problem lasted for 6 months
  1. VW Bora 1.6 problem lasted for 6 months
    Nov 2011
    Egypt
    This my first post here hoping to get help.
    My problem can be classified as cold start problem.
    When i startup my bora (1.6 SR.2005,AVU Engine) in the morning the engine rattles untill the car warm up ,then it ran fine.
    so i decided to order vag com interface to scan ECU for fault codes
    I found these faults stored in ECU
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-10 - - - Intermittent
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-00 - -
    16687 - Cylinder 3: Misfire Detected
    P0303 - 35-10 - - - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-10 - - - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16685 - Cylinder 1: Misfire Detected
    P0301 - 35-10 - - - Intermittent
    I replaced CTS,spark plugs and ignition wire set ,the these faults didn't come back again except lambada sensor.
    I thought that i have bad MAF sensor,first i cleaned it but nothing except a little improvement in acceleration.
    I disconnected it and drove the car, i found a bit better performance
    i decided to clear codes and disconnect the MAF and drove the car for a day.
    i found these codes
    16486 - Mass Air Flow Sensor (G70): Signal too Low
    P0102 - 35-10 - - - Intermittent
    16497 - Intake Air Temp. Sensor (G42): Signal too High
    P0113 - 35-10 - - - Intermittent
    That's because of disconnection for MAF,but i wondered that Lambada sensor didn't come back again as usual.
    by the way when i generate readiness to my ecu,all test passed eveb lambada sensor regulation ,the pops up again
    any ideas
    Waiting for help as soon as possible
  2. Exclamation Re: VW Bora 1.6 problem lasted for 6 months
    Nov 2011
    Egypt
    Any body there?!!!!
  3. Re: VW Bora 1.6 problem lasted for 6 months
    46 Post(s)
  1. A4 Quattro - Pirellis only lasted 15k miles
    By Noel Murray in forum Wheels and Tyres
    Last Post: 27-02-2012, 01:28 PM
  2. how long has your clutch lasted?
    By mpk490p in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-03-2010, 05:31 PM
  3. Longlife service lasted only 12 months
    By karenfletcher@b in forum TT - 8N Forum - 1998 - 2006
    Last Post: 25-02-2009, 10:54 PM
  4. Help!! ESP problem after 2 months of getting car!!?
    By carlos2006@hotm in forum Golf MK5 - 2004 - 2009
    Last Post: 07-01-2009, 11:47 PM
  5. It was good while it lasted.....
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 22-08-2008, 07:23 PM
