Thread: quick question regarding ccm/ccu thingy under passenger carpet??
Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
  1. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #31
    May 2012
    Glasgow
    Quote Originally Posted by Peter D View Post
    Yep the pulley has failed. Remove and inspect the compressor may be OK. Regards Peter
    Thanks Peter!, will do.
    I also did another vcds scan of hvac (didn't know I had to scan this separately), it came up with a faulty air quality sensor, but it doesn't seem like this has any bearing on the compressor issue I have..
    now to try and get some time with car & spanners...
    2001 A6 Avant 1.9tdi 130 manual AWX 203k+++ "Come to kindly terms with your @ss for it bears you." - John Muir.
  2. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #32
    May 2012
    Glasgow
    So family issues, as they should, have taken priority over this little car issue so i'm no further along yet, but I have noticed the aux electric fan doesn't cut in with aircon on (econ button off), even with temp settings at 'LO' on climate control. Dunno if this has any bearing on anything...
    cheers!
  3. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #33
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by mrnice View Post
    cheers!
    Just replaced my aux electric fan on my 2002 Allroad after 4 years since it failed!. Failure of this fan does not affect aircon and no vcds fault will show up. In my experience this fan is only required on very hot days (not many of these in Scotland - but lots in south France!). On such a day IF the car is stationary and idling for a while, the aircon will start to blow hot. Drive on and the viscous fan easily copes with the arcon.
    To check if the fan is goosed (it runs ALL the time when ECON button is off, so after a few years the brushes wear out), remove the connector near the power steering reservoir (remove plastic cover first) and, on the fan side connect an ohmmeter. If you get NO reading (as in my case) then the fan is faulty.
    I had a go at repairing mine but the armature well worn. Also, you have to burr off the end plate (side where motor bolts onto fan) and be VERY careful reassembling if it was just the 4 brushes needing replacement. Having seen it, I would recommend a NEW fan. Downside - £240 new OEM or, in my case, £100 compatible. AND BEFORE ANONE CHIPS IN - the compatible ones CANNOT be any worse than the OEM piece of junk!
    1 1 0
  4. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #34
    May 2012
    Glasgow
    Thanks!, I'll check this out
  5. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #35
    May 2012
    Glasgow
    Quote Originally Posted by ceilidhalfie View Post
    can anyone shed light on why the aux fan would be on all the time with econ button pressed, I mean what Is the purpose of that?,
    It's not really necessary for the heater and deffo not for the cooling system (especially on a diesel), just curious
  6. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #36
    london/ UK
    It's spinning to maximize the cooling on the evaporator when at idle or slow moving traffic !
  7. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #37
    May 2012
    Glasgow
    Quote Originally Posted by adamss24 View Post
    That makes sense but ceilidhalfie said it spins constantly when climate contr is in econ mode, surely evaporator isn't in use then?
    ps is it possible to remove the aux fan without removing the front panel or am I dreaming?
  8. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #38
    Nov 2011
    Duns Scotland
    11 Post(s)
    WITH ECON OFF ie ECON light is OFF and thus aircon is running - aux fan is running.
    If you wish to route the cabling of the new fan as per the old one and replace all the cable fasteners and ties, you need to put lock carrier in service position. Being a "picky" chap this is what I did.
    Apparently, an alternative is to remove the top front driver's side cover of the cam belt - giving just enough room to get the fan out. You can then re-route the new cable over the top of the radiator to the connector at the power steering reservoir, leaving the old cable snipped and still in place.
    YOUR CHOICE!
  9. Re: quick question regarding ccm/ccu thingy under passenger carpet??
    #39
    May 2012
    Glasgow
    Gotcha thanks, I'll get on it soon, family flu for weeks has limited progress to research and asking lots of questions, spanners out soon
  1. ccu question
    By scootir706 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2012, 10:40 PM
  2. Please Help Wet Carpet on Passenger Side
    By Tyroaudi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-04-2010, 10:03 AM
  3. Wet carpet in passenger footwell??
    By Midnightsky in forum Bora - 1998 - 2005
    Last Post: 25-12-2009, 09:41 PM
  4. Wet Passenger carpet (Again) 2004 A6 Please Help.
    By midge6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-12-2008, 03:08 PM
  5. How to lift the carpet in passenger footwell?
    By Niall76 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-08-2008, 08:30 AM
