Thread: Wiring Problems
  1. Wiring Problems
    Norwich
    i have put a boost vavle in my 1997 a3,i want to wire it up to the light swich but i dontknow which wires to attach them to, i need one connected to 12V lighting, one to ground and one to 12V ignition swich,
  2. Re: Wiring Problems
    May 2007
    Preston
    Not sure about the wiring part, but hows the boost valve? Have heard nightmare stories so haven't fitted one to mine. How much difference has it made and which make is it?
    Rusko
  3. Re: Wiring Problems
    Norwich
    sorry i meant boost gauge!!! the boost gauge is good and works well, i thought that the maximum boost for the turbo on my a3 was about 4psi but mine goes up to 8psi, boost valve is next, will tell you what its like after its fitted, what did you hear was wrong with them?
  4. Re: Wiring Problems
    May 2007
    Preston
    From what i've read it shouldn't be any probs if you've got a boost gauge.
    If you wind up the pressure too far the ecu goes into limp mode!!
    Think 12-14psi is tops but DON'T take that as gospel!!
    Good luck...
  1. gamma to rcd200 wiring problems
    By kharva007 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-05-2007, 01:44 AM
  2. wiring vdo gauges
    By gteyes in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-05-2007, 07:59 PM
  3. wiring an amp in a mk4 TDI
    By bigwint in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2007, 03:36 PM
  4. Wiring?
    By bromine in forum Passat - Archive Topics
    Last Post: 10-02-2007, 07:33 PM
  5. wiring up an amp in a a3
    By jkruse123 in forum Audi A3 - Archive Topics
    Last Post: 08-12-2006, 03:46 PM
