Thread: A4 TDI 1.9 Sport Auto vibration - please help!
  1. A4 TDI 1.9 Sport Auto vibration - please help!
    Jul 2012
    Bristol, UK
    Hi all
    I've got a 53 plate Audi A4 1.9 TDI Sport estate and whilst driving from Bristol to Cambridge the other day it developed a vibration and I'm really struggling to decipher what is causing it. It's driving me nuts so any help will be most welcome.
    It started after a dual carriageway section. A vibration felt through the steering and throttle pedal almost as if the front tyres were out of balance. It only occurred whilst under load, cruising at around 60mph. It seemed to be not as bad at low speeds and similarly if I went up to 80/90 it also more or less disappeared. If I let off the throttle it disappears completely so I know it's not a wheel bearing.
    It's an auto box and i've noticed that whilst waiting at traffic lights in 'drive' with my foot on the brake pedal there seems to be a very slight vibration which could or could not be related...
    A quick look under the bonnet doesn't show any obvious problems (apart from the front belt looks a bit ropey) so I'm a bit stuck really...
    Sorry it's a bit vague but I'm hoping that it might be a common problem that one of you guys can spot straight away.
    Cheers Ian
  2. Re: A4 TDI 1.9 Sport Auto vibration - please help!
    Aug 2007
    Cambridge, Cambridgeshire, United Kingdom
    15 Post(s)
    Have you scanned for fault codes yet?
  3. Re: A4 TDI 1.9 Sport Auto vibration - please help!
    Apr 2012
    bradford
    Check the wheel balancing mate!!
    Audi A4 B6 TDI SE (170) blacked out everything apart from windows / custom plate surrounds / carbon fiber vinlyed trims / de - badged / remaped (130 - 170) / well looked after
    Job list: paint calipers black / fix acceleration vibration / replace alternator pulley / replace thermostat / replace window winders / keep car the running well
  4. Re: A4 TDI 1.9 Sport Auto vibration - please help!
    Apr 2012
    bradford
    did you find out what the problem was?
  1. Please Help 2.5 TDI Auto 2005 60k loud noise and vibration on cold start
    By nrrobinson in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-12-2015, 06:00 AM
  2. 2.5 TDI AUTO QUATTRO - vibration
    By seanpcashman in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-03-2011, 02:46 AM
  3. Audi A6 2.0 tdi Auto Engine Vibration etc
    By imastu pidgit in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-02-2011, 09:22 AM
  4. Sharan 1.9 tdi sport 2001 - Vibration
    By chalkmyster in forum Touran - Sharan - Caravelle
    Last Post: 13-05-2010, 08:12 PM
  5. TDI 130 Sport Clutch pedal vibration.
    By Tip Top Pete in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2010, 10:26 AM
