Thread: can i fit A5 wheels on my car?
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
  1. Re: can i fit A5 wheels on my car?
    #21
    Aug 2011
    Hornchurch
    1.8Turbo. Stage 1 Tuned 215bhp
    l Powerflow Cat Back Exhaust l Carbonio Cold Air Intake l Forge 007P Diverter l Stage 1 Remap l Stage 2 Carbon Kevlar Clutch l 40mm Apex Lowering Springs l HZ Altezza Front skirt l HZ Altezza side skirts l HZ Altezza spoiler l Votex Rear Bumper l 19" RS6 Alloys l 312mm Brake Upgrade l 2007 S-Line Interior l
  2. Re: can i fit A5 wheels on my car?
    #22
    Aug 2009
    kent
    thanks for this info man,
  3. Re: can i fit A5 wheels on my car?
    #23
    Aug 2011
    Hornchurch
    No Problem, hope it helps you as much as it helped me. it sort of helps you see why ET is so important as it brings the whole wheel in or out of the arch, so a lower ET will allow a wider tyre to be fitted than that with a higher ET.
  4. Re: can i fit A5 wheels on my car?
    #24
    Aug 2012
    redhill
    The lower ET has more offset the higher ET has a greater inset ie,A4 b6/b7 is about 43-45 and an A5 is 30-35,The problem is if you fit a lower ET wheel on your car it moves the center line out which can reduce your negative scrub radius causing tramlining and twitchy steering,Even a car like a RS5 which is designed to run these wheels is very twitchy to drive
  5. Re: can i fit A5 wheels on my car?
    #25
    Aug 2009
    kent
    ok but a rep at nirro.co.uk breakers said he put a5 rims on his a4 cab with no issues also saying i may need spacers!! is he talking sense or taking the ****?
  6. Re: can i fit A5 wheels on my car?
    #26
    Aug 2011
    Hornchurch
    Does he definately mean Spacers? and not Spiggot Rings? (I hope i'm not teaching you to suck eggs, and sorry if this sounds like i'm trying to tell you what you probably already know) The hub diameter of an A5 is bigger than that of the A4 so if you put the rims on without Spiggot rings the wheels will be putting all the weight of the car solely on the Wheel nuts which in time will sheer and loose the wheel down the road!!! thats why the spiggot rings are placed to rest the weight of the car on the hub which can take the weight. Spacers will push the wheel thurther out into the arch (giving the effect of a lower ET rating) so if your Wheels already have the "Wrong" ET and you add spacers then you will end up with the wheels hanging out of the arches.
  7. Re: can i fit A5 wheels on my car?
    #27
    Aug 2009
    kent
    Quote Originally Posted by sam.bird3 View Post
    exactly. thought he was taking the ****. dont really like a few guys down at nirro.co.uk east london. seems like they look at you then decide the price and availabilty. heard them take the **** out of another customer who didn't know what he was talking about. not his fault. only problem is they have most bits i want. they wanted 650 for 19 inch s line blades with good rubber but the rims looked scratched and kerbed to ****. i think thats too expensive. what do you guys think?
  8. Re: can i fit A5 wheels on my car?
    #28
    Aug 2011
    Hornchurch
    Quote Originally Posted by pollum View Post
    Look on ebay, i got my 19" RS6 Rims really good price. Also for £650 you could go to Rochford Tyres (Southend) and get a set of 19" RS4 Reps brand new with Budget Tyres
  9. Re: can i fit A5 wheels on my car?
    #29
    Aug 2011
    Hornchurch
    Just googled Nirro's and seen it is only 5 Mins up the Road from me, never even knew it was there lol
  10. Re: can i fit A5 wheels on my car?
    #30
    Aug 2009
    kent
    you should check em out as they have everything. there was a leather interior there from a b7. always busy so they seem abrupt. i shouldn't have knocked them really cos they always help...
  1. Winter wheels - will they fit my new car
    By BiTDI in forum Wheels and Tyres
    Last Post: 07-07-2012, 12:08 PM
  2. will b5 and b6 wheels fit my b7
    By Bryden Leask in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-08-2011, 08:12 PM
  3. Will S3 wheels fit my car?
    By coolbird in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-12-2009, 09:38 AM
  4. will these wheels fit on my car ?
    By plumo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-01-2009, 12:19 AM
  5. Will these wheels fit my car?
    By DVR80 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-03-2008, 11:30 PM
