Thread: Mk 5 GT Tdi 170 Hesitation on Acceleration around 2000rpm
  1. Mk 5 GT Tdi 170 Hesitation on Acceleration around 2000rpm
    Aug 2011
    Northwich, England
    I have an 08 mk 5 GT Tdi 170 which has been in and out of the VW dealers recently due to hestitation on acceleration around 1800-2000rpm, a problem which is gradually getting worse. The problem is intermittent, sometimes it accelerates smoothly through 2000 revs but approx 50% of the time it will stutter for a second or two then take off as normal.
    Initially no errors were being registered by the engine mgmt system, so VW had nothing to go on, they forced a regen thinking it could be DPF related, this seemed to work for a day or so but then recurred.
    Now I am getting a combination of warning lights on the dash, either the amber DPF light comes on or an amber Engine Fault Workshop message appears with flashing amber coil and the car goes into limp mode.
    From this latter error VW reckoned their diagnostics advised them to change the Turbo wiring loom at a cost of £200. Again this seemed to work for a day or two but now it's back to it's stuttering best!
    If I add to this that it also cuts out occasionally, but only when I'm coming to a stop at lights for instance, but will restart straight away if I either let the clutch out or quickly turn the ignition off and on again.
    VW dealer thinks the next step maybe to look at the Turbo but you can imagine I'm loath to fork out for further work if they aren't sure what the problem is.
    Any ideas or advice for my tale of woe?
  2. Re: Mk 5 GT Tdi 170 Hesitation on Acceleration around 2000rpm
    X
    Firstly get your £200 back as their efforts have;nt worked. Secondly get a vw specialist local to you.
    07 2.0 TDI (imported by me) RCD510 with MDI installed can gateway upgrade not required Jetta sport front end with projector lights
  3. Re: Mk 5 GT Tdi 170 Hesitation on Acceleration around 2000rpm
    Aug 2011
    Northwich, England
    I have just been to a local VW specialist, they immediately sussed out it was all DPF related, they reduced the particulate build up from 63% to 20% and put some fluid into the tank which reduces the temperature at which the DPF gen takes place. Stuttering and warning lights all disppeared for now, but I'll keep an eye on it for a while before I claim a victory.
    Totally agree about the £200, that's my next job!
  4. Re: Mk 5 GT Tdi 170 Hesitation on Acceleration around 2000rpm
    Aug 2012
    Paisley, uk
    Hi guys,
    Not meaning to hijack, my gt sport 170 tdi had the same problem, spent £290 on that wiring loom last thursdayl, doesn't work, stuttering again today, Waste of money.
    But what I did notice was a load of oil over the alternator, looks like it coming from the intake manifold where it meets the block, most importantly it's fresh oil.
    It might be a place to look for you aswell.
    How did you get one getting your money back?
    Al
  5. Re: Mk 5 GT Tdi 170 Hesitation on Acceleration around 2000rpm
    Jun 2012
    Peterborough, UK
    Hi Hodger, did you get a repeat of the problem?
    Passat 2.0 TDI Sport 5dr Estate (170PS) 3C5 M6F CBBB (Sold 08/04/2019)
    Polo 1.2 TSI 77 kW (105PS) A05 6R1 4F2 (Mk5) M6F CBZB
    If you post for help please close the loop and post how you finally solved the problem.
  1. Replies: 12
    Last Post: 15-05-2012, 08:16 PM
  2. Audi A4 170 Quattro hesitant / flat spot up to 2000rpm
    By R1LLE in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-09-2011, 10:48 PM
  3. Question TDI 170 + 140 Acceleration
    By jakerade in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-08-2011, 03:21 PM
  4. Tdi Acceleration hesitation
    By Hardcorism in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-09-2010, 07:48 PM
  5. Please Help Hesitation on acceleration
    By robat282 in forum Bora - 1998 - 2005
    Last Post: 06-03-2010, 05:26 PM
