Thread: heater blowing warm when set to cold
  1. heater blowing warm when set to cold
    Oct 2009
    spennymoor co. durham
    HI my mk 5 1.9 tdi has recently started to blow out warm air when set to cold, any ideas ????
  2. Re: heater blowing warm when set to cold
    Jul 2012
    United Kingdom
    Quote Originally Posted by williamjack View Post
    My Mk5 1.9Tdi has been doing the exact same thing for a while now. It was very intermittent, sometimes whatever setting I started the car on it would stay on that, sometimes it would work, but now its stuck on cold only.
    I had a garage do a diagnostics (about £63 at a VW garage, I did it at independent for £55 because I had a different fault they fixed, but I've been quoted £35 at kwik-fit previously). Mine requires a v68 flap motor to be replaced. I've been trawling these forums trying to find someone who has done this on a Golf mk5 before but so far haven't been able to.
    I'm not saying that this is actually what needs replacing on yours, as I think there could be other motors attached to the system, but if it is then here is what I got quoted for prices:
    Cost of v68 flap motor: £97
    Cost of labour at independent garage: approx £157 based on 2.5 hours worth of work.
    Cost of labour at vw Garage: £300.
    The part is quite difficult to get to I believe as its located under the passenger side dash beneath the glove box - this is what I've read in the forums for Polo's.
    If anyone has the instructions on how to replace a V68 flap motor on a Golf MK5 (plus pictures) that would be much appreciated. I'm currently in the process of buying VCDS, as I believe you have to do a reset, or adaptation as they call it for the new motor to work.
  3. Re: heater blowing warm when set to cold
    Jul 2012
    United Kingdom
    At the very least, does anyone know where I can find this? Is it on the passengers side or drivers side of a UK MK5 Golf (Right hand drive)? Once the glove box is out, how difficult is it to get to, and is it easy to determine which motor it is, as I believe there could be a few doing different things...
  4. Re: heater blowing warm when set to cold
    Sep 2008
    chester
    17 Post(s)
    Not a mk5 but many times on a A4,the motors stick inside on the plastic gears,take the glove box out and ascertain which is sticking by operating on manual,the red lever is heat on a A4
  1. Please Help 2.8 quattro, heater blowing luke warm air
    By colabear in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-02-2011, 11:01 PM
  2. Please Help Heater blowing cold
    By BIGBADBORA in forum Bora - 1998 - 2005
    Last Post: 30-10-2010, 12:44 PM
  3. help please heater blowing cold
    By markspark71 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-12-2009, 03:02 PM
  4. heater blowing cold
    By lee a4 in forum Chat - Anything with wheels
    Last Post: 09-09-2008, 01:26 PM
  5. Climate Control - Cold blowing warm.
    By JezzaL in forum Audi A3 - Archive Topics
    Last Post: 04-06-2008, 05:46 PM
