Thread: problems with steerin brake control unit ross tech
  1. problems with steerin brake control unit ross tech
    Jul 2012
    manchester
    hi guys audi a3 2.0tdi 2004 after just fitting a new brake switch had the car scanned and following fault codes 1. accelerator position sensor 2 g1052. alltitude boost presure sensor too lowp1592 3, steering limit stop no or wrong adapter 4,steering angle senser no adaption 5, system funtion test wont clear ,lateral aceleration sensor no adaption6. steering angle sensor no adaption , these are the code . been doing a little research and ROSS TECH points to brake control unit not sure if its correct and its a bit outa my knowledge wanted to ask advice rather than buy all items on the codes maybe it could be down to 1 simple thing thanks
  2. Re: problems with steerin brake control unit ross tech
    Jan 2012
    Coding Something
    Do you have vcds yourself, if so post a proper log on here.
  3. Re: problems with steerin brake control unit ross tech
    Jul 2012
    manchester
    cheers for help buddy bit the bullet and took it to a garage and was told things needed coding thanks anyway so complicated these audis
  4. Re: problems with steerin brake control unit ross tech
    Jan 2012
    Coding Something
    It needs a boat load of calibrations.
  1. Latest vag com - From Ross Tech
    By Joshua in forum VCDS - General Questions
    Last Post: 26-01-2010, 11:54 PM
  2. Which software do i download from ross tech?
    By spence_star in forum VCDS - General Questions
    Last Post: 13-04-2008, 12:30 AM
