Thread: econ button on....... no aircon?
  1. econ button on....... no aircon?
    Jul 2011
    blackwood
    as above, ive had a look online and there seems to be loads of problems with the econ button on.
    whats the best way to find out whats causing the problem
    thanks
  2. Re: econ button on....... no aircon?
    You need to detail the issue. Econ on means no aircon, the car uses the heater only to raise temperature if needed.
  3. Re: econ button on....... no aircon?
    Jul 2011
    blackwood
    Quote Originally Posted by Eshrules View Post
    the econ button is on and wont turn off
  4. econ button on....... no aircon?
    46 Post(s)
    Diagnostic scan is needed - you might need a regas or a common failing part is a pressure sensor but check first.
  5. Re: econ button on....... no aircon?
    Jul 2011
    blackwood
    so a scan will pin point the problem
  6. Re: econ button on....... no aircon?
    Yes
  7. Re: econ button on....... no aircon?
    liverpool
    iagnostic function. Just press and hold the CIRC & ECON buttons on the Climatronic panel. Then the Climatronic system will perform a self-diagnostic test. If it displays "444 00" there is no faults stored. The codes that are available are an exact match for the regularly published list of Climatronic DTC's, except they are shown in hexadecimal instead of decimal. For example, the fault code 04FA on the front panel is 1274 in decimal. If you're not familiar with converting hexadecimal numbers to decimal, you can do so using the Windows accessory Calculator. From the View menu, switch to Scientific, pick Hex and enter something, then switch to Dec.
  1. ECON Button???
    By curryholic in forum Touran - Sharan - Caravelle
    Last Post: 28-01-2010, 07:55 PM
  2. Please Help Econ Button
    By Phortys in forum Golf Plus
    Last Post: 02-11-2008, 12:32 PM
  3. Question Econ button - when to use?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 23-09-2008, 06:56 PM
  4. ECON button
    By noshock65 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-08-2008, 02:20 PM
