Thread: Comfort control Module
  1. Comfort control Module
    Sep 2009
    United Kingdom
    So i have had a small flood into the CCM. I think its washer fluid rather than rain water. Anyway, im gonna replace it as one of the connectors has badly corroded. My question is this. My part number is 4B0 962258 K. Could i replace it with part number 4B0 962 258 X or 4B0 962 258 H. Or do i have to replace it with an exactly the same number part?
  2. Re: Comfort control Module
    Nov 2011
    Duns Scotland
    11 Post(s)
    Quote Originally Posted by Snaga View Post
    ETKA says "H" was replaced by "K" on 01012003. Looks like either will do and "K" is still current. A quick call to you Audi dealer will confirm.
  3. Re: Comfort control Module
    Sep 2009
    United Kingdom
    Thanks for the info. Had a llok at the CCM myself. Managed to get the big black plug out with a bit of WD40. Board looked ok. cleaned terminal pins, Got a new connector block ffrom TPS and a set of connectors. Spliced the cables onto the new connectors, installed them in the new connector block. I now have functioning windows, hazard lights and interior lights. thanks for the help.
    James
    Oh and on a side note. It wasnt water ingress. the rear washer water pipe had popped apart and was spraying washer fluid under the floor!!! Reconnected and taped up so shouldnt be a problem anymore.
  1. Comfort Control Module fault or something else?
    By schomosport in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-12-2010, 06:48 PM
  2. Comfort Control Module - serviceable or not?
    By Golf-Princess in forum Golf MK4 - 1999 - 2004
    Last Post: 25-04-2010, 07:06 PM
  3. comfort control module
    By logic5 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-02-2010, 05:54 PM
  4. Please Help Comfort Control Module
    By VWP02 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-01-2009, 05:11 PM
  5. Comfort control module issue
    By hotdog in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-07-2008, 11:47 AM
