Thread: golf mk5 audio upgrade
  1. golf mk5 audio upgrade
    macc70 Guest
    I have a new golf mk5 and the first thing I need to change is the stereo
    I have been told that the rear speakers even if they are in place might not be connected. I have noticed that the head unit does not provide a fade function so I have no control over the rear speakers in any case. What I want is a head unit with sony nw-hd5 compatibility and 4 good quality speakers in the doors. please point me in the right direction.
  2. Re: golf mk5 audio upgrade
    Coventry
    What is your current stereo in the golf? rcd300 or rcd500 Why would you want to upgrade?
  3. Re: golf mk5 audio upgrade
    macc70 Guest
    Thanks for your reply I want to use my sony nw-hd5 in the car and would like rear aswell as front speakers I am going to have to find out if there are any speakers installed or not I have a RCD300 installed
  4. Re: golf mk5 audio upgrade
    Colchester, England
    Just done this on my 'S' spec 2005 TDi
    There were no speakers or wiring for rear speakers which is why i gather (from other forums) there is no fade option (apparently it appears when you connect rear speakers)
    I had some speakers (17" 2-way pioneers) and wiring installed for me as it didn't have time to do it myself.
    I then installed a facia adapter to convert to single din (**tip** you get what you pay for - my £8 ebay item wasn't the best looking/fit)
    Below links help with removing:
    http://uk-mkivs.net/forums/p/18010/170840.aspx#170840
    http://www.golfmkv.com/forums/showthread.php?t=693
    From there I then purchased a converter for the can-bus wiring and fakra to standard aerial (with signal booster which is required for mw/lw)
    After this the only other issue is because the can-bus wiring there is no switched live so i ran a wire behind the steering column to the fuse box wired in an in-line fuse and then used a simple blade connector to slot into a free fuse way which i found to be a switched live.
    There may be more expensive can-bus converters which actually do the switched live for you a bit like what is required for people who tow and have a car with can-bus rear light clusters. Someone else might have more info on this as i am unsure.
    Once i had correct wiring i just slid in my sony mp3/bluetooth stereo.
    If only VW weren't so tight with rear speakers and used standard wiring eh! - 5 min/£10 job turned into a marathon £160 job
    Hope this helps
  1. Audio upgrade?
    By AUDICAB99 in forum 80 - 90
    Last Post: 29-05-2007, 11:15 PM
  2. Golf audio upgrade
    By Paul_mkV_golf in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-05-2007, 05:24 PM
  3. mk2 golf brake upgrade help!
    By buzmuzguz in forum Golf MK2 - 1984 - 1992
    Last Post: 12-05-2007, 08:12 PM
  4. Golf Driver Upgrade
    By Michand in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 13-12-2006, 10:38 PM
  5. Golf GT TDI or Upgrade the Passat V6TDI
    By LWW in forum Chat - Completely Off Topic
    Last Post: 30-10-2006, 08:50 PM
