Thread: 3,0 TDI glow plug And DPF Sensor Error codes
  1. 3,0 TDI glow plug And DPF Sensor Error codes
    Aug 2012
    Hartlepool
    Hi All,
    Firstly sorry for the long post..
    I'm a new member here, hoping someone can help me out with a couple of fault codes.
    Car is a 3.0 TDI Quattro Cab on a 56 plate. approx 77,000 miles.
    I have VCDS, and will attach the errors below.
    A couple of weeks ago, the DPF light came on (On it's own, no management light)
    This was shortly after startup, and no errors seemed to be stored on VCDS.
    It went off after switching the ignition off and on again.
    I then had a 150 mile trip with no issues and drove during that trip in sport at approx 75mph for at least 20mins. (thinking it may need a re-gen)
    The light has not been back on since, I have measured the soot levels after the trip and they read as below after a 30 mile drive:
    Monday,23,July,2012,08:48:02:10074
    VCDS Version: Release 10.6.4 (x64)
    Data version: 20110418
    Address 01: Engine (8H0 910 401 A)
    08:47:40 Group 104
    0.24 (no units)
    9.0 (no units)
    13.5 (no units)
    1230 km Mileage
    08:47:40 Group 102
    266.8°C Temperature
    265.5°C Temperature
    7 mbar Pressure
    21 mbar Pressure
    So, I thought everything was ok..............However I now have engine / emission warning light on (see below errors)
    Sunday,05,August,2012,15:16:36:10074
    Address 01: Engine Labels: Redir Fail!
    Control Module Part Number: 8H0 910 401 A HW: 8E0 907 401 AL
    Component and/or Version: 3.0L V6TDI G000AG 0060
    Software Coding: 0011171
    Work Shop Code: WSC 01286 386 08256
    VCID: 204BE4B38A53
    3 Faults Found:
    005659 - Glowplug for Cylinder 2 (Q11): Open Circuit
    P161B - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Status: 01110001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 123808 km
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.29 V
    Duty Cycle: 24.5 %
    Temperature: 16.2°C
    005663 - Glowplug for Cylinder 6 (Q15): Open Circuit
    P161F - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 123808 km
    Time Indication: 0
    Freeze Frame:
    RPM: 882 /min
    Torque: 97.5 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 14.29 V
    Duty Cycle: 24.5 %
    Temperature: 16.2°C
    009299 - Diesel Particle Filter; Differential Pressure Sensor: Implausible Signal
    P2453 - 001 - Upper Limit Exceeded
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Mileage: 125203 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Speed: 0.0 km/h
    Pressure: 14 mbar
    (no units): 0.0
    Temperature: 300.9°C
    Absolute Pres.: 20.4 mbar
    Temperature: 12.6°C
    Readiness: 1 1 0 0 0
    The glow plug error has been coming up for a while, any suggestions or should I just change all six plugs at this mileage?
    Any thoughts on the DPF warning light and then sensor error, faulty sensor?
    Cheers All
  2. Re: 3,0 TDI glow plug And DPF Sensor Error codes
    Aug 2007
    Asnières-sur-Blour, Vienne, France
    Hello Ritchie,
    Did you find out the problem yet?
    My wife's A4 3.0 tdi quattro cab has come up with all 6 cylinders glow plug open circuit fault codes.
    I cannot believe all glow plugs have simultaneously blown, I wonder is there a controller which could be faulty?
    I hope yours is sorted,
    Regards,
    Michael
  3. Re: 3,0 TDI glow plug And DPF Sensor Error codes
    Aug 2007
    p.s. I should point out that the glow plug light is not illuminated except on startup as normal and the car is not and has not been in limp mode with flashing glow plug light.
  4. Re: 3,0 TDI glow plug And DPF Sensor Error codes
    Aug 2012
    Hartlepool
    Hi Michael,
    Mine was indeed two duff glow plugs, I changed all six as I figured they had all done the same mileage and with two failing decided that was the way to go. All six seems unlikely, but not impossible I suppose. You can apparently measure the resistance of the individual plugs to see if they have failed.
    For anyone having similar DPF issues to mine, the problem was down to the differential pressure sensor. Cost about £45 + Vat from Audi and car had been ok for approx 2500 miles.
    I do now have some new "issues" of course, but thats for another day! (flickering xenon and drivers seat moving on its own and flattening the battery...)
    Regards
    Richie
  5. Re: 3,0 TDI glow plug And DPF Sensor Error codes
    Aug 2007
    Thank you Ritchie,
    If ever I have a duff glowplug I always change the set to keep the current even, but I have never had a set of 6 go at the same time.
    What is odd is that after I cleared the fault codes the light came on again when my wife next used the car, but before I could check VCDS she filled the car with diesel and the light went out. There has never been a fault code for the fuel level sensor which baffles me, but with these new complicated cars that is not difficult.
    Regards,
    Michael
  1. Please Help dpf flashing glow plug and eng management light on??
    By ahsanx in forum Golf MK5 - 2004 - 2009
    Last Post: 17-01-2019, 09:52 PM
  2. Replies: 3
    Last Post: 07-02-2012, 08:50 AM
  3. DPF, Flashing Glow Plug and Engine Mang Light on..
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2011, 01:06 PM
  4. Please Help Audi 3.2 with glow plug error??
    By neilkaz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-03-2010, 09:36 AM
  5. glow plug circuit fault codes
    By hoffmeister in forum Golf MK5 - 2004 - 2009
    Last Post: 10-10-2009, 09:46 AM
