Thread: Fitting a CD changer
  1. Thumbs up Fitting a CD changer
    May 2006
    Has anybody on here fitted a CD changer to a Bora? (2001). I want to fit it in the boot, but not sure how easy it is to feed the cable neatly through to the front. I don't want to open a can of worms.
    Any suggestions (of other/better places to fit it?) would be appriciated.
    Oct 2005
    Not sure on Boras but on the Passat, depending on the phase of the moon, the tides and the colour of the sky, there was often wiring pre-installed.
    To run your own wire should be fairly straight-forward if you've done it before.
    I'd go for an OEM unit that way you have all the correct connections and there'll be no need to run power etc. One wire from the HU, out under the passenger side dash, up the side of the car under the door sills and into the boot area (maybe in the first aid compartment a la factory install)
    May 2006
    Cheers, I'll give it ago!
    Jun 2006
    Droitwich, Worcestershire
    Hi, i have a 2000 Bora and the other day i had to change a rear bulb. To do this i had to open the first aid compartment, where beneath this i noticed what looks like the brackets and wiring harness for a cd changer. So, off to VW for a quote for a cd changer.........£350 and thats not fitted, Ebay here we come!
    Hope that helps.
    May 2006
    £350 not fitted!!! ebay is the way to go Dave. I got mine off ebay for £25!
    but that wasn't a VW OEM unit. (i'd already got the changer before I posted)
    I don't have any brackets holes or wires coming into the first aid compartment but I think i'll stick it there and give it a go.
    Thanks for the feedback.
    May 2006
    Sorted!
    Fed the wire under the passenger dash (like mycarsavw said) and under the door sills. Once into the boot area I fed the wire into the light cluster area and into the first aid compartment. The changer fits into the first aid box bracket like a glove. Nice.
    Thanks again.
    Oct 2005
    Glad to be of some help
  1. Fitting VW Golf MKV armrest CD Changer
    By tdw in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
  2. DIS Fitting
    By gazaaa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2007, 07:55 PM
  3. Fitting a later ADR 1.8 20v into an A4
    By Llaniboy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-04-2007, 09:00 PM
  4. FITTING ARMREST
    By noogman in forum Passat - Archive Topics
    Last Post: 08-11-2006, 02:18 PM
  5. Fitting CD changer
    By SkillSte in forum Polo - Derby - Lupo - Fox
    Last Post: 29-06-2006, 03:33 PM
