Thread: fuel temperature sensor
Results 1 to 8 of 8
  1. fuel temperature sensor
    england
    Morning all.
    Trying to locate the fuel temperature sensor on my golf 1.9 Gt tdi pd130. 2003, ASZ engine.
    Carried out a scan using vcds lite.
    Results are:
    17571 fuel temp sensor
    (G81) open or short to plus.
    P1163-35-10 intermittant.
    Reason for scan was workshop emmissions engine management light on dash.
    Many thanks guys.
  2. Re: fuel temperature sensor
    Southampton, UK.
    Never knew there was one. Some talk of it here.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  3. Re: fuel temperature sensor
    Pembrokeshire
    22 Post(s)
    i have known the wiring to them to break at the sender. iirc it is on the right as per the other forum.
  4. Re: fuel temperature sensor
    england
    Just had a look at the engine and followed the fuel line from the pump to this item pictured.
    Is this the fuel temp sensor.
    Thanks for your help guys
  5. Re: fuel temperature sensor
    Pembrokeshire
    22 Post(s)
    i think thats it, yes.
  6. Re: fuel temperature sensor
    england
    Thanks for all your help guys. Phoned TPS and the sensor is £20 Part no 038906081B will be getting one at the weekend. Thanks again guys
  7. Re: fuel temperature sensor
    Pembrokeshire
    22 Post(s)
    before spanking money, remove the plug and peel back the loom to check for wire damage. you only need to do it from the sensor to the main loom, so a 5 min job.
  8. Re: fuel temperature sensor
    england
    I checked the connector plug and wire when I took the photo no obvious sign of damage. cleaned conectors with electrical cleaner, pluged back in and reset DTC. Went on a 5mile test drive. all ok until engine upto temp then emissions workshop back again. Re scaned came up with same DTC. so looks like new sensor.
    Thanks again for your advice.
    Regards simon
  1. Fuel Temperature Sensor
    By chris_r in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-08-2013, 09:28 AM
  2. Fuel Temperature Sensor keeps failing
    By unkateef in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-08-2012, 04:48 PM
  3. Fuel Temperature sensor
    By gazwilson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-03-2010, 10:07 PM
  4. Faulty fuel temperature sensor?
    By Froggy_130PD in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2009, 04:42 PM
  5. Fuel temperature sensor
    By rplc1976 in forum Golf MK4 - 1999 - 2004
    Last Post: 09-03-2009, 02:29 PM
