Thread: what is the difference between BKP & BKD engines
  1. what is the difference between BKP & BKD engines
    Mar 2009
    I have had the oil pump disaster happen with my 2006 b6 passat, it has a BKP engine fitted, I have been looking for a second hand engine but the only BKP engines available are very expensive, making it not worth doing as the car has done over 140k and is fairly tatty, I have seen more BKD engines available at a lower cost, both are 140hp pd engines, anyone know what the differences are.
  2. Re: what is the difference between BKP & BKD engines
    Mar 2009
    not to worry I have now sent my crank to be machined & I will rebuild the bottom end of the original engine, it already has a gear driven ballance shaft & a new pump drive spindle fits fairly snug into the shaft so hopefully I won't need to spend out on a new ballance shaft module.
    Thanks for reading
    Barry d
  1. Please Help 2ltr PD 16v cylinder head issues and bkp/bkd differences
    By 7ommy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-02-2012, 12:01 PM
  2. difference between asz and arl engines
    By j13hna in forum Bora - 1998 - 2005
    Last Post: 25-11-2011, 12:47 PM
  3. Question BKP head on a BKD engine?
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 20-10-2011, 08:26 PM
  4. Question will a BKP sump go on a BKD engine?
    Last Post: 12-06-2011, 07:34 PM
  5. Difference between old and new 3.2 engines?
    By Space Cadet in forum Archive posts
    Last Post: 13-02-2008, 06:14 PM
