Thread: door trim 2002 passat diesel
  1. door trim 2002 passat diesel
    Aug 2007
    can anyone please tell me how to remove rear door trim.I can only find one screw at the bottom of trim and removing this seems not to allow the trim to be removed
  2. Re: door trim 2002 passat diesel
    thread moved to the relevant section
  3. Re: door trim 2002 passat diesel
    Oct 2005
    Lutterworth
    Quote Originally Posted by sabullock View Post
    Pop the centre piece out of the door pull handle and there are two large screws to undo.
    Then prise it away from the door with something that will not damage the paint.
    Then lift it up and off the window channel after unplugging the wires.
    Passat Estate 2002 PD130
    Passat 1.8SE 1998
  4. Re: door trim 2002 passat diesel
    Aug 2007
    thank you for your help in removing trim job done
  1. Door trim
    By jimgad in forum Audi A4 - Archive Topics
    Last Post: 15-09-2007, 05:05 PM
  2. Door trim removal
    By trebor54 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-07-2007, 10:50 AM
  3. 2002 Passat estate trim
    By clivec in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2007, 12:18 PM
  4. Coupe door trim
    By Lewwy in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-05-2007, 10:21 AM
  5. 1999 A6 Door trim
    By graemeb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2006, 10:55 PM
