Thread: Vag Tacho, Will it code in a replacement ECU and clocks?
  1. Vag Tacho, Will it code in a replacement ECU and clocks?
    Jul 2012
    Leicestershire
    Hi all, right I'm trying to rule out the ECU whilst trying to sort out my 1.4 cutting out. All I need to know is can Vag Tacho code in and make work-
    1. A replacement ECU of the same part number
    2. A replacement set of clocks of the same part number (old clocks are playing up that's why I want to swap them).
    Is the SKC code in the clocks or the ECU? Just need know before chucking any more money at it for no reason.
    By the way I have had the car plugged in and it is throwing up fault codes for stuff I have already replaced (codes were cleared) hence why I want to rule out the ECU.
    Thanks Gareth
  2. Re: Vag Tacho, Will it code in a replacement ECU and clocks?
    Pembrokeshire
    22 Post(s)
    so what codes are coming up. just because a code shows for a particular part doesn't always mean the replacing it will cure the fault.
  3. Re: Vag Tacho, Will it code in a replacement ECU and clocks?
    Jul 2012
    Leicestershire
    00518 Throttle valve potentiometer-G49 Short to ground
    00513 Engine speed sensor-G28 implausible signal
    00281 Vehicle speed sensor R/P- G68 implausible signal (not 2 worried about that 1)
    Symptoms are- Car runs fine when cold, once it gets warm it cuts out on over run or light throttle. When it cuts out though the rev counter drops instantly e.g cuts ignition, normally cuts back in again after a couple of seconds but the odd time you have to knock the key back and turn it back on again (whilst still moving) to get power back. Also when warm it runs fine on the spot but if you turn the steering on the spot it again cuts the ignition and it dies. Even if you rev it on the spot and turn the wheel it just dies. It'll run all day on tickover as long as you don't touch the steering wheel. Seriously doing my head in now, considering selling it that's how bad it's getting now!
    Thanks Gareth
  4. Re: Vag Tacho, Will it code in a replacement ECU and clocks?
    Pembrokeshire
    22 Post(s)
    ok, interesting, so what have you done so far replacing things ?
  5. Re: Vag Tacho, Will it code in a replacement ECU and clocks?
    Jul 2012
    Leicestershire
    Coilpack (new)
    crank sensor (used but made no difference)
    Camshaft sensor (again used)
    Throttle body taken off and cleaned (made it run a bit smoother)
    Did an engine swap last year due to cambelt tensioner failing and has been good as gold for 9 months then developed miss-fire. Can't understand what componant would be breaking down only when hot. If it was a wiring fault then it would be a more irregular fault, also if it was still crank sensor then surely it would struggle to start. Speedo stopped working after I swapped the engine and even 2 VW specialists can't find the road speed sensor on the gearbox! It's a 98 1.4 with an AHW engine. Really reluctant to sell it but i'm not chucking money at if forever just to have a car that's only any good to go into town on a cool day lol.
    Gareth
  6. I have a 99.5 vr6 it is running rough and many fault codes! Help please and thanks!
    Sep 2014
    rochester ny
    I have a 199.5 vw jetta vr6 AFP!I am getting many electrical short to ground codes and i cleaned the terminals under the battery box and the car is still running really rough and really rich! I noticed that on the alternator there is a visible nut that is on a screw and there is no wire attached to it! The kid i bought the car from just had the alternator replaced. The camshaft sensor also had oil in the plug and was bad and i replaced it and still runs rough and when i down shift it pops like a lil bit of backfiring going on! My MIL and ABS and a the other lights in the middle cluster will not illuminate and my temp gauge is also not moving.I am going to check the converter to see if it is clogged but i want to figure out the electrical short faults that i am getting! Where do all the wires from the alternator run to and where are all the major grounds for the car i cant find that info! New plugs,coilpack,cam shaft sens,oil pan,thermostat,100 and 409 relay also replaced the TPS sensor.Here is the scan! Any help would be great this is my first V-DUB!
    20 Faults Found:
    18010 - Power Supply Terminal 30
    P1602 - 35-10 - Voltage too Low - Intermittent
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - Intermittent
    16687 - Cylinder 3
    P0303 - 35-10 - Misfire Detected - Intermittent
    16497 - Intake Air Temp. Sensor (G42)
    P0113 - 35-10 - Signal too High - Intermittent
    16486 - Mass Air Flow Sensor (G70)
    P0102 - 35-00 - Signal too Low
    17834 - EVAP Purge Valve (N80)
    P1426 - 35-00 - Open Circuit
    17950 - Angle Sensor 1 for Throttle Actuator (G187)
    P1542 - 35-10 - Implausible Signal - Intermittent
    17952 - Angle Sensor 1 for Throttle Actuator (G187)
    P1544 - 35-10 - Signal too Large - Intermittent
    17580 - Angle Sensor 2 for Throttle Actuator (G188) Signal too Low
    P1172 - 35-10 - - Intermittent
    17633 - Fuel Injector for Cylinder 1 (N30)
    P1225 - 35-10 - Short to Ground - Intermittent
    17637 - Fuel Injector for Cylinder 5 (N83)
    P1229 - 35-10 - Short to Ground - Intermittent
    17635 - Fuel Injector for Cylinder 3 (N32)
    P1227 - 35-10 - Short to Ground - Intermittent
    17638 - Fuel Injector for Cylinder 6 (N84)
    P1230 - 35-10 - Short to Ground - Intermittent
    17880 - EVAP Leak Detection Pump
    P1472 - 35-10 - Short to Ground - Intermittent
    17843 - Secondary Air Pump Relay (J299)
    P1435 - 35-10 - Short to Ground - Intermittent
    17829 - Secondary Air Injection Solenoid Valve (N112)
    P1421 - 35-10 - Short to Ground - Intermittent
    17636 - Fuel Injector for Cylinder 4 (N33)
    P1228 - 35-10 - Short to Ground - Intermittent
    17923 - Intake Manifold Valve (N156)
    P1515 - 35-10 - Short to Ground - Intermittent
    17634 - Fuel Injector for Cylinder 2 (N31)
    P1226 - 35-10 - Short to Ground - Intermittent
    17525 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2
    P1117 - 35-10 - Short to Ground - Intermittent
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 H
    Component: ABS/EDS 20 IE CAN 0001
    Coding: 03604
    Shop #: WSC 00066
    VCID: 3663DDFA12827BAE71B-4B1A
    3 Faults Found:
    01276 - ABS Hydraulic Pump (V64)
    16-00 - Signal Outside Specifications
    00290 - ABS Wheel Speed Sensor; Rear Left (G46)
    35-00 - -
    00287 - ABS Wheel Speed Sensor; Rear Right (G44)
    35-00 - -
    Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
    Part No: 1J0 909 609
    Component: C AIRBAG VW3 SG 0002
    Coding: 00067
    Shop #: WSC 00066
    VCID: ECD7BF929C4E717ED7F-4B1A
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
    Part No: 1J0 919 951 B
    Component: A4-KOMBIINSTR. VDO V57
    Coding: 06262
    Shop #: WSC 00000
    VCID: 2F6DE89EEDD84A6632D-5142
    1 Fault Found:
    01039 - Coolant Temperature Sensor (G2)
    29-10 - Short to Ground - Intermittent
    Address 46: Central Conv. Labels: 1J0-959-799.lbl
    Part No: 1J0 959 799 AJ
    Component: 61 Zentral-SG Komf. 0001
    Coding: 04096
    Shop #: WSC 00066
    VCID: 8603ED3AA2E2AB2E21B-4AE8
    Subsystem 1 - Part No: 1J1959801C
    Component: 61 T?rsteuerger. FS0001r
    Subsystem 2 - Part No: 1J1959802D
    Component: 61 T?rsteuerger. BF0001r
    Subsystem 3 - Part No: 1J4959811C
    Component: 61 T?rsteuerger. HL0001r
    Subsystem 4 - Part No: 1J4959812C
    Component: 61 T?rsteuerger. HR0001H
    4 Faults Found:
    00953 - Interior Light Time limit
    25-10 - Unknown Switch Condition - Intermittent
    01358 - Internal Central Locking Switch; Driver Side (E150)
    27-10 - Implausible Signal - Intermittent
    00912 - Window Regulator Switch; Front Left (E40)
    00944 - Heated Exterior Mirror; Passenger Side (Z5)
    35-00 - -
  7. Re: I have a 99.5 vr6 it is running rough and many fault codes! Help please and thanks!
    Aug 2011
    Meath
    You would need VCDS to code in a new ECU it's a lot cheaper than VAG tacho too. You'll need the pin code for your car and the donor ECU pin if it's second hand. Depending on the age of the car you can get the PIN from a main dealer or a good locksmith. ECM and cluster swapping for Immobilizer 3 - YouTube
  1. having problems with matching keys on ecu / tacho
    By turbobugger in forum VCDS - General Questions
    Last Post: 05-11-2008, 07:14 PM
  2. Vag-com & Vag-Tacho
    By rhinopower in forum VCDS - General Questions
    Last Post: 17-03-2008, 01:11 PM
  3. Vag-Tacho using Vag-Com lead?
    By xaindsleena in forum VCDS - General Questions
    Last Post: 11-03-2008, 12:16 AM
  4. VAG Tacho help
    By andyha2000 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-11-2007, 12:07 PM
  5. Vag Tacho
    By mobitune in forum VCDS - General Questions
    Last Post: 19-10-2007, 09:52 PM
