Thread: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    slee02 Guest
    Hi mrdon. Yeah mine is exactly the same except it does not do it in 2nd or 3rd gear. It only jerks in 1st, it does make it better when its in tip mode and i can usually change into second before it jerks.
    I spoke to Indie Tech in Milton keynes and they suggested that i get it in there for a test run and diagnosis.
    Is it worth getting a warranty for it. I saw one online for high mileage cars. It was about 350 and because its got high mileage you have to pay 50% of the claim.
  2. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    Jun 2009
    Gloucestershire
    Hi all
    I have a 2004 1.9tdi 130 cvt auto avant with 181k on clock.
    Same issue with mine again. Previously ECU went at 95k and then hydraulic pump stripped gearbox at 109k so full rebuild.
    Debating on what to do if it implodes again..... I have changed the Oil at 40k but I get the impression this is just a flawed gearbox
    Sent from my GT-I9100 using Tapatalk 2
  3. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    Jul 2012
    romania
    Most probabli the forward clutch has a slip, common failure of this gearbox 01J. If in revers its working perfectly ,than the problem is what ive mentioned.
  4. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    slee02 Guest
    I would like to think that an oil change will solve the problem.
  5. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    Aug 2012
    redhill
    Hi all i'm a newbe to this site but thought i should add my thoughts,is the gearbox juddering or just has a delay ,it is quite common to have a delay but if its the front clutch it will judder on 20-30% throtle as you pull away
  6. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    slee02 Guest
    hi. mine jerks on pull away at about 1300 revs. and when cruising about 50mph it revs up from about 1200-1400revs. i thank its bad news for mine.
  7. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    #17
    Aug 2012
    redhill
    Quote Originally Posted by slee02 View Post
    Is it as bad in tip mode or does it improve if so i suspect it is the front clutch,do you know if its been uprated to 7 plates
  8. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    #18
    slee02 Guest
    is not as bad in tip mode. any idea how much for front clutch repair. its only the six plate
  9. Re: 1.9 tdi sport, slight jerk on multitronic gearbox, is this normal?
    #19
    Aug 2012
    redhill
    Usually works out about £800 with seven plate upgrade ,double oil flush and gearbox in and out
  1. Audi A4 Automatic Gearbox Problem Leak Jerk Or Rev Etc
    By cbi004 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-12-2013, 11:30 AM
  2. Question 2006 2.0 tdi A4 multitronic gearbox
    By Cowboy1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-02-2011, 10:02 PM
  3. slight judder multitronic
    By shabazmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-02-2010, 07:09 PM
  4. A5 2.7 TDi multitronic gearbox issue
    By tetstb in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 15-12-2008, 11:09 PM
  5. Please Help A6 TDI 2.5 multitronic gearbox problem
    By johnsson in forum Chat - Anything with wheels
    Last Post: 30-09-2008, 12:35 PM
