Thread: Airbag light is on
  1. Airbag light is on
    Apr 2007
    Took my car for its MOT today and noticed while driving home that the airbag light was ( its never been on before )
    Does anybody know how to remove this...
    Thanks to anybody who can help..
    Audi A6 1.9TDI AWX 2004
    vwnige@yahoo.co.uk
  2. Re: Airbag light is on
    Mar 2008
    High Wycombe
    Really, you need a fault code read to tell you which airbag is causing the problem, and to reset the light.
    Without a code read, it's just a guess, but the usual suspect for airbag lights is the connectors under the driver and passenger seats.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  3. Re: Airbag light is on
    Aug 2007
    Midlands, Uk.
    I remember having exactly the same problem a few years back after an MOT. The light came on because the rear centre seat belt was left connected and seem to remember reading about a fault with the switch in the latch.
    Anyway, once disconnected and cleared it never came back, I've never used the centre belt...
  4. Re: Airbag light is on
    Pembrokeshire
    22 Post(s)
    part of the test now is to make sure the drivers seat latches in 3 different positions, so the tester has possibly moved the seat further than usual and disturbed the connector.
  5. Re: Airbag light is on
    Aug 2007
    New Romney Kent
    You will need someone with VCDS to reset the light.
    VCDS HEX-NET registered owner (Covers all VAG cars)
    PM me if you require scans or adaptations doing in S.E. Kent, can unlock SFD.
    Audi TTS 8S
    VW ID.3 Tour
  6. Re: Airbag light is on
    Apr 2007
    Thanks to everybody who replied,the problem is sorted now..
    I noticed that the back seat belts were all fastened, i unfastened them all and the light went off.
  7. Re: Airbag light is on
    Mar 2008
    High Wycombe
    I'm going to have to try that now then.
    How does this work then? why doesn't it light up if there's rear seat passengers? Are there weight sensors in the seats?
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  1. Please Help Airbag light
    By Danny Whyte in forum Chat - Completely Off Topic
    Last Post: 09-10-2011, 07:38 AM
  2. Please Help A3 Airbag Light
    By stynesy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-02-2011, 02:40 PM
  3. Please Help Engine Light & Airbag Light stay on
    By sobberz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 01-06-2010, 07:27 AM
  4. Airbag Light
    By gjb0535 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-03-2009, 11:22 AM
  5. Question Airbag light - on and off
    By egTT in forum Audi A3 - Archive Topics
    Last Post: 14-10-2008, 09:01 PM
