Thread: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
  1. Post Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Aug 2010
    Leeds
    Well after 2 years of loyal service my a4 2.0t blew up (2005), the tensioner on the cam chain on the back of the head failed meaning the cams went out of timing etc so all valves bent casing cracked as chain punched out etc.
    so looking for a new engine mine is bgb and i know other a4 code is bwe i think and would both be straight swap,
    however i cant find either,
    but can find a bwa from an a3, i know i will need to swap sump and inlet manifold etc but just checking oil inlet out lets for turbo on block are same so all aux items off a4 will fit onto a3 block?
    anyone done this any issues and is the bare block head same?
  2. Re: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Aug 2010
    Leeds
    Please anyone who could avise i would be greaful as i need and engine asap!
    Southern County Softy
    20 Post(s)
    The A3 is transverse and the A4 is longitude.I wouldn't think it would fit without a lot of felting.
    follow me on twitter...kiteaudi...
    A4 2.5 tdi QS (mapped)
  4. Re: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Aug 2010
    Leeds
    i know wha you mean but my understanding the block and head is same just with different mounts and aux items to match, just need some comfirmation?
  5. Re: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Aug 2010
    Leeds
    YES IT DOES FIT
    i have no option so went for a BWA 2007 a3 engine,
    just had to swap sump,
    oil pickup,
    thermostat housing,
    general coolant hoses,
    engine mounts,
    cam covers,
    thats about it, all in and working well, much quieter than old engine but could be refinements that came with the BWA engine code and the internal changes, apparently it had different valve springs and piston tops to make them more refined/quiter for direct injection petrols
  6. Re: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Nov 2014
    Estonia
    Hello!
    Can you help about this problem:
    Does VW Passat 2.0TFSI 2007year 147kw (BPY engine) fit to Audi A4 2.0TFSI (BGB engine)??
    If yes, whats the differences?
  7. Re: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Jan 2010
    kent, england
    10 Post(s)
    Sorry to hear about your car, was it a 2.0TFSI? I have one the same age, did you have your cam belt done etc at the correct interval, are there any other preventative measures that could be taken to avoid this happening?
    I may be wrong but aren't these engines also used in Golf GTI's?
  8. Re: Will an a3 2.0t go into an a4, bwa to replace a bgb HELP
    Sep 2015
    southampton uk
    How on earth did you get it to fit just tried this with mine and the mechanic cant get it in because the clutch housing mounts are completely different??
    Sent from my SM-G900F using Tapatalk
  1. BUL BWE differences?
    By vagcar in forum 2.0T, TSI and TFSI - Engine
    Last Post: 02-05-2012, 09:37 PM
  2. what shall i replace it with
    By sbt in forum Chat - Anything with wheels
    Last Post: 10-03-2012, 09:57 AM
  3. EGR - shall i take it out or replace?
    By paulos130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2011, 04:09 PM
  4. Question What can i replace / clean?
    By leon_richard in forum Leon
    Last Post: 17-12-2009, 11:12 PM
  5. Replace CV boot
    By guv.c in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-03-2009, 06:37 PM
